user private calling number lost
You found one ?
You know about one ?
Share it !
Lee0125
Post by Lee0125 »
My custoner's oxe R12.4 have a problem. set private calling number to all user , when oxe reboot , some and same user's private calling number lost
. I use its ops and create new database , private calling number is ok , not lost . So , should I recreate oxe's database ? or is it have other way to fix it?
Re: user private calling number lost
Upgrade to latest R12.4 patch and reproduce.
Lee0125
Post by Lee0125 »
Thanks,Frank . But the oxe is the last version R12.4-M5204-90。The customer's oxe database needs to be rebuilt,I have verified that this method is feasible in my lab.....
there are tools to rebuild the DB, did you use them?
Return to “Bugs & Security issues”
