I have a problem with a switch 6850. login miniboot applies bootvx command to access the mode VxWorks.
now I can not enter via serial.
send me the following:
> bootvx
## Ethernet MAC address not copied to NV RAM ## No elf image at address 0x01000000 ## Not an ELF image, assuming binary ## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.
1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0 ## Starting vxWorks at 0x01000000 ...
Best regards
