Setting smaller time for DISA response on OXO
Shadow
Post by Shadow »
Hello guys
It is posibile to set a small time for DISA response?.I want that the msg for DISA to enter after first ring not after the 3rd.
Thank you in advanced
et
Re: Setting smaller time for DISA response on OXO
Post by et »
System Misc./ Memory R/W/ Other Labels/ DisaAnsTim by default 3C (hex) or 060 (dec) = 6 sec. Reduce it.
Shadow
Post by Shadow »
Hello
Thank you for your help .I guess this info is found in the doc right?
Maybe i didn`t try harder to find it
Shadow
Post by Shadow »
Hello
I try this but nothing happened.Still the welcome mesage for DISA enters after first 3 rings
I realy don`t know where to look now
elkiwi
Post by elkiwi »
ADsaAnsTim: DISA on analogue trunk: Ring duration timer for automatic answer of an incoming call to DISA. Default value 64 Be carefull, 100 ms intervals. Source: Noteworthy addresses TC.
Shadow
Post by Shadow »
Hello
Thank you, this time was fine.DISA answers now after one ring.
Return to “Configuration”
