Microphone sensitivity when handfree on 4020
Well..
Here is a good one: I am on site, and the customer complain about the 4020s being too sensitives. There is a AC that's ON all the time and make a huge noise. I just opened a trouble ticket with NOC, because I don't know what to change under System / UA audio parameters
4035T..?
What's that model, I never heard about it.
Actually, the NOC talked to me about parameters to change in
MGR / System / UA Audio Parameters
or something like that. It's a very sensitive parameter because it affect all UA boards. I will make some test and will let you know. I will also try to get a 4035T free for 'test' and see if it changes anything. Thanks for the trick !
PS: Do you like this idea of forums ?
sshynk
Post by sshynk »
Not sure what the actual model number (manufacture code) was. That was 4-5 months ago.
Love the forum. Great place to share ideas and ask questions !!
Okay, here is my solution: I had an answer from Alcatel giving me a lot of information about those system parameters that we should not change. So I spoke with the customer that did agree on change the phone location from under the AC to another part of the room, and then it worked ...
Return to “ON SITE TROUBLES”
