Dear All,
In OXO R.6 we are using Auto attendant. when we call the number it's ringing 4 times then connecting to AA welcome message. we want to reduce the ring 1 or 2.
I was trying to reduce the "disaans" time in debug labels but nothing happen.
Any help...thanks in advance.
cheers.
To reduce the incoming call Ring
ACSE Business R.9.x
Re: To reduce the incoming call Ring
Whats the way for the incoming attandant call? Direct in attandant group the mailbox lines, attandent forwarded to mailbox group or dynamic routing to the mailbox group. I assume you use the last way - than you have to reduce the timer 1 (from normaly 12 sec).
Hi Silvio,
thanks for your reply..you mean to reduce the timer 1 in Vm extension numbers..i will try that and let u know...thanks a lot..
cheers,
pandian
cheers,
pandian
ACSE Business R.9.x
no, timer 1 in active attendant group.
kpm82
try changing the off hook delay in general parameters of voice processing
