Can someone please provide latest SIP firmware for ALE-20h
sip8419P
ALE-20h SIP Firmware
Re: ALE-20h SIP Firmware
Done, you really should be getting access to the Portal, or dealing with your Business partner
Thank you! I am able to upgrade using the firmware you have provided.
Then noticed my device still shows (none), under Software Versions for SIP version.
Can you please provide me the latest SIP firmware.
Appreciate the help!
eliseo1024
Hello, to change the firmware to SIP can it only be done with the Alcatel software? They gave me one of these phones to work with Asterisk.
BR
BR
