Lanpower issue
blackglobes
Lanpower issue
Post by blackglobes »
Hello :) ,
one of our OS6450-P10 Release: 6.7.2.191.R04 GA seems too have some issue with lan power.
I have set the command "lanpower start 1" (also tried it with single ports).
i have connected an OAW-AP1221 but the AP dont get power.
I checkt the show lanpower command. So at status there is Undefined.
The On/Off is set to ON.
Other Informations showen:
Slot 1 Max Watts 120
0.0 Watts Actual Power Consumed
120.0 Watts Actual Power Remaining
120 Watts Total Power Budget Available
1 Power Supplies Available
Someone have an idea? Can i try something?
Regards Florian
Re: Lanpower issue
have you tested with other poe devices (phones, other APs)?
Try with a new release, check your miniboot.
In the knowledge base in the BP I have found this issue for your release in article 000041573. But there is no real solution/explanation for it. You can try something in the dshell. And if this isn't helpfull than you need to replace the switch....
blackglobes
Re: Lanpower issue
Hi Silvio,
yes i have tested other devices also all ports.
I will Update aos and miniboot if possible.
Do you have some hints for the dshell commands?
Florian
Re: Lanpower issue
If you have no access to the Business Portal (BP) than ask you supplier for the mentioned article. there you finde the commands.
best regards
Return to “OmniSwitch 6450”
