8001 SIP extension
bibo
8001 SIP extension
Post by bibo »
Hi All
We using OXE R11.2.2 and SIP extension 8001, but when i make the call between 8001 SIP the call not work with "Not acceptable here", i have tried to change the code for 8001 phone to G711 and other but not work
Please help
Re: 8001 SIP extension
Please post logs from OXE
bibo
Post by bibo »
This attached is log call, please help
fery_s
Post by fery_s »
do you have license for sip extentions?
"Wed Mar 14 17:27:45 2018 1103[CMotorCall::methodInviteReceived] nb available licenses=0 ."
and also did you create 8000 and 8001 directory in your oxe?
bibo
Post by bibo »
Yes, i have SIP extension as bellow, i have create 8000 and 8001 with SIP Extension type, but cannot call
345 M SIP extension users = 2/ 298
With 3 party SIP phone (Favil) the call work but with Alcatel-Lucent 8001 DeskPhone it is not work
Please help
jetcster
Post by jetcster »
What is the neqt 798 on your PBX ?
Do you have the same call trace for 3rdparty phone, which is OK ?
There is an OXE bug which didn't load sip licenses on r11. Are you in latest patch?
jetcster
Post by jetcster »
cavagnaro wrote: 15 Mar 2018 08:51 There is an OXE bug which didn't load sip licenses on r11. Are you in latest patch?
Wed Mar 14 17:27:45 2018 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R11.2.2 l2.300.31.b
bibo
Post by bibo »
And now, both SIP 3 party and 8001 SIP phone not work
SIP/2.0 488 Not Acceptable Here
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
User-Agent: OmniPCX Enterprise R11.2.2 l2.300.31.b
Reason: SIP;cause=488;text="Outgoing call isn't allowed here"
Which sip 3rd party? Please explain
Return to “SIP”
