OXE common hardware vs crystal hardware
Ask your questions, regarding data or voice!
Waelkaamalzaki
Post by Waelkaamalzaki »
Dear Unleashed team,
I have a new design for OXE with specifications (400 analog extension , 48 digital extensions, 20 analog trunk, 2 T2 ISDN trunk)
should I go to common hardware or crystal hardware offer ?
Is their any design recommendations from Alcatel side for choosing crystal hardware or common hardware.
Thank you for your support
Re: OXE common hardware vs crystal hardware
Take a basic sales training please.
Read system documentation where differences are explained.
Follow Actis
Waelkaamalzaki
the above design can work both OXE crystal hardware or OXE common hardware.
I want a document that support this matter.
As said, Actis is your friend. The document is generated there and technical background is on system documentation
Just configure both hardware - compare price, required space in cabinet etc.
For 400 analogue extension (especially with long line) - I prefer crystal hardware.
But if site - big building with many floor - with common hardware you can install IP media gateway on each floor.
So - not easy to give good advice.
junoooni
Post by junoooni »
I was in a same situation few months back and I opted for Common HW.... It was cost-effective compared to ACT and easier to manage... Only drawback i felt was the need of Patch Panels to connect PBX and User side MDF.... with ACT, you can use the cables and terminate extensions directly on wall....
Check out below thread to get more info:
http://www.alcatelunleashed.com/viewtop ... 76&t=26989
Waelkaamalzaki
Thanks junoooni, vad and cavagnaro
Return to “Pre-Sales”
