Hi!
I want to implement an overflow from a 4059 attendant console to an digital extension (4039).
The overflow should happen when there are too many waiting calls or eventually on time.
Does anybody know if that is possible ?
(I've tried lots of options in entities, attend group, call distribution list,..., nothing worked)
THANKS a lot
Attendant overflow to extension ?
zanex
Re: Attendant overflow to extension ?
calls will never overflow to an extension from an attendant if you put them in the entity or att grp CDT.
There is a feature called attendant assist that you can configure on normal handsets that trips when the number of calls reach a certian point but not on no reply
domino
Thank you for information.
Can you or someone else can please give me another tip, how to setup the feature "Attendant Assist" ?
I've checked the settings on the normal set but could not find anything. Also in the documentation
I was not able to find something helpfull for me.
zanex
I dont have a doc and i cant remeber how to do it but a couple of things i forgot to mention - the set needs to be 4035 i have never tried it on a iptouch or 9 series.
domino
I think I've just found the way...configure the set as multi-line and then
a progr. key with function "Attendant Assistant".
But then error msg "This type of key does not exist for this type of set" appears.
So it seems not working with my 4029/4039 set.
Another question:
If I will get one 4035 set, is it than possible to overflow or forward calls from that to an 4029?
(4059 attendant -> 4035 attendant -> 4029/4039 set)
My problem is, that the solution should be as flexible as possible. And I cannot by 10 peaces of 4035.
Another question:
Bump,
I have 2 4068 attendants and whant to use another phone, 4068, to assist the attendant via the attendant assistant feature.
But I am also getting the error "This type of key does not exist for this type of set", does it only work on 4035 phones?
yes, only 4035 as attendant assistant possible.
regards...
regards...
