Software Upgrade on OXE
Telecom_Repair
Post by Telecom_Repair »
Our OXE is running a very old version of software. I was wondering what the best way is to get this upgraded to a more recent release
login: mtch
Password:
CHORUS Release MiX V.3.2r4.1.5 COMP-386
xa000001
Copyright (c) 1984 AT&T
Copyright (c) 1990-1994 Chorus systemes
All Rights Reserved
# The role of the CPU is MAIN
Application software identity
R3.0-c1.532-5-z-uk-c3s2
Business identification: R3.0
Release:
DELIVERY c1.532
Patch identification: 5
Dynamic patch identification: z
Country: uk
Cpu: c3s2
ACD VERSION
realease : 4
bug_fixing : 4
protocol_id : 45
version_dy_hr_stat : 6
(1)xa000001>
Re: Software Upgrade on OXE
You need new license for it. Not free.
Telecom_Repair
Can anyone help with a quote for a new license?
murraya
Post by murraya »
HI, I think you will need to find a local BP to give you quotes on products.
If you leave details of your location then someone may contact you.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Telecom_Repair
I'm located in The UK
hi
new release
new ops
new CPU
and may be 8770 for management (option)
And $$$$ won't be cheap
byronwak
Post by byronwak »
Can I do the software upgrade myself if I already have an ESS OBDII cable? Or do I need to visit you?
hi
from that release to newest one R 12.2 lots of method/way and hardware has been involved
db translation via temporarly release , u have to make transition
no more pc installe i think ....
if ure well trained why not ? otherwise ask ur bp
Return to “Shelf”
