8440 - how to call mailbox number after pressing 1
hassansalem
Post by hassansalem »
voice mail server (OmniTouch 8440 Messaging Software) is configured fine, and when i called the voice mail from the set, i hear "if you have a mail box within the system press 1"
then i pressed 1 But i don't know how to add mail box number to call it after pressing 1 ???
So, how to create a mailbox number to call it after the voice guide ??
Thanks,
Re: 8440 - how to call mailbox number after pressing 1
It is saying that because you haven't configured the numbers on the user so the system can identify him by ANI or you are calling from a non registered number.
Follow the system guides to create a user
Return to “OmniTouch 8440 Messaging Software”
