Analog Extension problem
Aamir-KHI
Post by Aamir-KHI »
Hi all,
In OXO, I have a problem with analog extensions. When I put my receiver back to phone after talking on a trunk line, I get some callback sort of ring on my phone. But when I listen it on receiver, nobody is there. Any solution ??
Bunch of Thanks,
Aamir.
Aamir-KHI
Post by Aamir-KHI »
Nobody to answer ???????
Re: Analog Extension problem
Usually that happens when on the other side line is open, you get a ringback. Check your trunks
Jigger
Post by Jigger »
check under its feature's, master mailing is prolly ticked?? untick that and give it a go....
ive never had the issue but ive had people mention to me that seems to be the cause?
hung.le
Post by hung.le »
I have the same problem, but still don't have solution for it.
Oxosaysno
Post by Oxosaysno »
I kinda had this problem once before. however it was analogue and digital phones all affected and it was due to the disconnect timers on the analogue trunks. what type of lines are being used?
hung.le
Post by hung.le »
I am using Analog trunks.
jopatini
Post by jopatini »
hung.le wrote:I am using Analog trunks.
I had the same problem in OXE R7.0. The sulution in this case is the followng:
For the involved SLI:
Shelf - Board - SLI position
Send Init Dynamic Msg = TRUE
Param By Default = FALSE
In the go down menu - Dynamic Init Parameter set following parameter:
P20 = 2
P21 = 0
P22 = 15
P23 = 0
P24 = 2
P25 = 0
P26 =22
P27 = 1
Please RESET the coupler SLI after the above modification.
This is an OXO issue, not an OXE.
He may do the same but on noteworthy addresses.
Return to “Configuration”
