hi
i have this client where they have nddi and pcm e1 trunks. they have over 500 ip users and over 200 tdm sets. the problem is will the ip sets. when a call is made (out going) during the call the set gives a buzz sound, and even when i put it on hook the sound is this still there . after few minutes the phone resets and becomes normal. but yet again if i make a call the same issue.
the data center say they did not change any settings on the switches. by the way all switches are alcatel as well.
the system release is R10.1-j2.501-23-sa. i have taken a incvisu and found the phone sets resetting incidents, when i checked further the phones having 40x8GEE has the problems.
when the mirror is of the phone the following keeps on running
1)hq-cpu06> telnet 10.111.64.133
Trying 10.111.64.133...
Connected to 10.111.64.133.
Escape character is '^]'.
NoePhone > mit rror set lan
mirror set lan
#mirror#
mirror OK
NoePhone > 000-00:05:25.830 AUDIO : eptDevice_cfg_sidetone: mute sidetone on device 0
000-00:05:30.080 arpresolve 10.111.64.1 OK
000-00:05:30.080 BCM : RTPT - RTPT: sockets rtp=18 rtcp=19
000-00:05:30.090 AUDIO : eptDevice_cfg_sidetone: mute sidetone on device 0
000-00:05:34.300 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.320 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.340 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.360 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.380 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.400 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.420 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.440 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.460 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.480 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.500 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.520 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.540 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.560 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.580 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.600 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.620 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.640 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.660 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.680 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.700 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:05:34.720 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:06:28.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:06:28.590 BCM : EPT - eptSBdisconnect: ERROR duplex disconnect failed src 80 dst 84
000-00:06:28.590 BCM : EPT - streamDevDetach: ERROR setting switchboard disconnection
000-00:06:28.590 BCM : EPT - HDSP: Resource manager error 3584, sub-error 80
000-00:06:28.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:28.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:29.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:29.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:29.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:29.600 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:29.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:29.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:30.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:30.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:30.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:30.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:30.800 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:30.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:31.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:31.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:31.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:31.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:31.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:32.000 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:32.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:32.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:32.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:32.590 BCM : EPT - streamModify: error resetting RTP stats
000-00:06:32.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:32.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:33.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:33.200 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:33.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:33.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:33.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:33.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:34.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:34.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:34.400 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:34.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:34.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:34.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:35.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:35.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:35.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:35.600 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:35.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:35.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:36.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:36.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:36.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:36.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:36.800 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:36.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:37.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:37.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:37.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:37.730 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:37.930 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:38.000 BCM : EPT - hapiGetTask: Error getting RTP stats for stream 0 vhd 80
000-00:06:38.130 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:38.330 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
000-00:06:38.530 BCM : EPT - HDSP: Resource manager error 3584, sub-error 82
Connection closed by foreign host.
(1)hq-cpu06>
(1)hq-cpu06>
any idea why this keeps happening?????????
ip phones noice and reboot
IP and Voice over IP
Split
Re: ip phones noice and reboot
Post by Split »
Do you use encryption? It sounds like a problem with encryption ......
hi split
no they dont. there is a nother guy having the same issue over here. please check viewtopic.php?f=118&t=22659
the problem got solved. the whole network got shut down. after the network was restored the problem never occurred. the reply from alcatel lucent support was that they think it was a problem from the network and its a QOS problem..
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
