Unable to connect to server OV
This application replaces the OmniVista 4760
emeza
Post by emeza »
Hi guys, the system OV was working properly, after a while I see this error "Unable to connect to server"
Name server: localhost
Port: 636
Anyone had a similar problem?
Atte.
Etmeza
Re: Unable to connect to server OV
Check if server services are running at least.
emeza
Post by emeza »
Hi tot3nkopf, Is running: NMC service manager/NMC CMISE sever/ NMC Java Service....
emeza wrote:Hi tot3nkopf, Is running: NMC service manager/NMC CMISE sever/ NMC Java Service....
And you want us to guess which might be the problem. Please search this forum as this has been debated many many times...
corwin
Post by corwin »
Of course , connection error is critical and several post report similar issue... Each with different root cause.
Hence some methodology is required to avoid Q&A post.
The start is comparaison:
Client on server and client on remote pc
If remote Pc cannot connect it can be a bad client installation or a firewall setup not allowing client to server connection.
Then if both client fails, look at server health
A server reboot could help without having to dig into complex analysis, log ...
If still failure then the hard way start...
All nmcxxx service started?
If not look at log files
8770/log/nmcsvcmgrX.log
It will give you the start service failure info
Like not enough space
No com with ldap db
Finally analysis can start by looking at the client connection process
On server, you have
a log for local client
8770/client/bin/....log
And you can also look at server log in charge of credential Check
Nmcsecurityserver
Hope this Will help you
safwa
Post by safwa »
Hello everyone ,
please I have the same issue and not all NMC services are up and I encounter the following warning in the logs:
[13/02/2025 14:41:02] 2044 svc_mgr: Warning: InternalAlarm DLL : Can't bind LDAP Server for AlarmServer IOR
[13/02/2025 14:42:16] 1072 svc_mgr: Error: connection to LDAP server failed (error 85: Timed out)
[13/02/2025 14:42:16] 1072 svc_mgr: closing LDAP connection
[13/02/2025 14:42:16] 1072 svc_mgr: Error: cant extract last threshold for LDAP
[13/02/2025 14:42:16] 1072 svc_mgr: Error: cant extract last threshold for SQLA
You need to restart the services. this works 99% of the time for me with the same issue
safwa
Post by safwa »
Thank you Frank
But I receive this error message" error 1067 the process stopped unexpectedly ..." when I try to restart the services.
Any advice please ?
oldboy
Post by oldboy »
safwa wrote: 21 Feb 2025 05:43 Thank you Frank
Any advice please ?
There are child services stop the NMC Service Manager first and restart it, it should then start the child services
Return to “OmniVista 8770”
