I find my 6400 switch continu to reboot without stop .
I cannot stop it ..
What Can I do to fix it .. please advice ..
Below is the output from console
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.08.16 09:25:06 =~=~=~=~=~=~=~=~=~=~=~=
PANIC: Remove USB Flash drive due to Bus Over-current threshold exceeded
Insert a good USB Flash drive and activate USB interface (usb enable)PANIC: Remove USB Flash drive due to Bus Over-current threshold exceeded
Insert a good USB Flash drive and activate USB interface (usb enable)Target Name: vxTarget
User: target
Attaching network interface lo0... done.
The current date and time is:
Coordinated Universal Time (UTC): FRI AUG 16 05:41:28 2013
Local time: FRI AUG 16 13:41:28 2013 LOCAL
Starting dynamic software load from '/flash/working/'...
Error accessing /flash/working/K2Ios.img. (errno = 0x27100001)
loadRemaining: Unable to load image file '/flash/working/K2Ios.img'.
***** Error loading image - Rebooting witho0?sR+NW??????aG?J
B?-???D???c????I?i?S???g?Kq?f?k??@k?@b??+??!)D1?CR?+|H??<??yk???????????=?'?9?p???-Y??{??5??????u?W??v=f?M???F}???u>5W????=???~??=/^???????>7^????????????????{????<V??[??s??8????????=>??{9?k?)?Z??USB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 562 Initialized
M824xHCI Controller found.
Waiting to attach to USBD...PANIC: Remove USB Flash drive due to Bus Over-current threshold exceeded
Insert a good USB Flash drive and activate USB interface (usb enable)Done.
0xffffde0 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
TFFS detected, mounting TFFS file system
Adding 10807 symbols for standalone.
Error on line 8: 'boot fsck 1
'.asciiBootParamsParse() failed.
WARNING: '/flash/boot.params' appears to be corrupt !!!
WARNING: Copying '/flash/boot.params' to '/flash/boot.params.CORRUPTED'...
WARNING: Removing '/flash/boot.params'...
Creating '/flash/boot.params' with defaults.
Boot parameters are:
'tffs(0,0)lanswitch:default e=10.255.24.81:ff000000 h=192.168.10.1 g=10.255.24.181 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS kernel version: 6.4.5.474.R02
VxWorks (for Freescale MPC8247 ADS) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Jul 25 2013, 05:21:38.
Copyright Wind River Systems, Inc., 1984-2006
CPU: Freescale MPC8247 ADS. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-PANIC: Remove2013 USB Flash drive. All Rights reserved
due to Bus Over-Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
currePortions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
nt thresholdPortions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
ePortions of code copyrighted by RSA Security, Inc. All Rights reserved
xceeded
Insert a Portions of code developed by the Carnegie-Mellon University.
good USB Flash dri
User: target
Coordinated Universal Time (UTC): FRI AUG 16 05:42:59 2013
Local time: FRI AUG 16 13:42:59 2013 LOCAL
JCJ,P?1????
R*K~B$rB?"J
bR?fRp?!???????Lo2cVX? NQ??jF??Y???Y?J????nRr?y?HN?9LBo?Cj?
