Anyone tested Extender Gbics with 6900
devnull
Post by devnull »
I have a customer who wants to install 6900, but he has some old (62,5µ) fiber buried to remote locatations.
He is using LC 100Mbit SFPs now, but we want to use Gigabit, where possible.
Using 6850 we could go for SFP-GIG-EXTND, using a 6900 i could go for new fiber, which is no option at the moment.
So any insights whether it could work with a SFP-GIG-EXTND in a 6900?
benny
Re: Anyone tested Extender Gbics with 6900
Post by benny »
Hi devnull,
Yes, that is supported (I remember it was missing from the XCVR guide ...)
Here is the support matrix for the GIG transceivers:
Benny
devnull
Post by devnull »
As the 10k is not listet, but same hardware plattform i guess it is supported there as well?
benny
Post by benny »
Yes, the OS10K supports that transceiver as well ... (it is part of the table that I posted, second column from the right).
B
devnull
Post by devnull »
You are right Benny i have been blind..
I think i got confused with the OA5510-GE, which i never saw before.
Return to “OmniSwitch 6900”
