Analog Trunks don´t hang up
zivadrums
Post by zivadrums »
Hi everybody,
I have an OXO PABX, my problem is some extensions make outgoing calls and 5 minute on the go cut the communication i already change some of the variables that i read in other topic about the busy tone detection.
viewtopic.php?f=273&t=12643&hilit=BTDMaxWOff
But now the operator phone get calls and have no answer, there is a lot of this calls.
I hope that you could help me.
Thanks in advance. :(
fernan05
Re: Analog Trunks don´t hang up
Post by fernan05 »
hello
which version of release is your oxo?
zivadrums
Post by zivadrums »
Thanks for answering,
i have the 710/061.001 version.
thanks in advance.
lmartinez
Post by lmartinez »
Hi, seem to me as a Busy tone detection problem. My advice it's try to capture the busy tone that is sent from your telco, best way it's using a PIMphony IP+ wireshark to get the media UPD packets. Then use a software like cool edit 2.0 or similar to get the real parameters of frequencies and time period, then configured that parameters on your OXO
Good Look,
Luis Martinez
briandang
Post by briandang »
Dear Luis,
can you help me how to detect busy tone buy IP Media and Wireshark?
or can you email to me at : chuong@omnicomm.com.sg
tks
Return to “Configuration”
