Public Network Category
lockout
Post by lockout »
Hi all!
I have an Alcatel 4400 omnipcx pbx. Now I have to set users permisions to make calls to a celluar network or to a foreign net. As far as I understood the permissions are set by using Public network category.
What I need to know - what categories are there, what kind of access each category allows?
 lqConsult/Modify: Usersqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
 x        x
 x                       Language Id. : 1                                                    x
 x        x
 x                        Secret Code : ****                                               x
 x                            Confirm : ****                                                 x
 x        x
 x                 Associated Set No. : 1429                                             x
 x                     Cost Center Id : 255                                                x
 x                   Cost Center Name : ----------                                      x
 x                  Charging Category + Justified                                     x
 x            Public Network Category : 2                                              x
 x       External Forwarding Category : 255                                        x
 x           Tel.Facility Category Id : 0                                                 x
 x             Connection Category Id : 0                                              x
 x              Hunting Group Dir No. : --------                                       x
 x            ACD Group Directory No. : --------                                    x
 x                 Pick up Group Name : ITnod                                       x
 x                 Reserved Time Slot + False                                         x
 x                 Voice Mail Dir.No. : --------                                          x
 x                    Voice Mail Type + No Voice Mail                                x
 x                 Paging Trunk Group : 255                                           x
 x        x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
tincho.rn
Post by tincho.rn »
Hi. I will give you a basic description:
Public Connection COS: use for allow conecction to external access (Public, Private: using PIN, Business:using business code). By default all trunk group have category 5.
Tel Facility Category: in Categories-->Tel Facility Category allow or not a lot of facilitys that have a set (user)
Conecction Category ID: use for allow or not connection (user to user) and transfers (this ID is for two different matrix: Categories->Connection Category and Categories-->Transfer Category)
Return to “Users”
