make a logical loop in a PRI/BRI access
tincho.rn
Hi. I am looking for a command or a way to do a logical loop in a ISDN access (if you know the command for a PCM-R2 will be usefull too). There is a command: loop and it seems to be the one I am looking for. Can anyone teach me how to use it? Thanks in advance.
- frank
From the documentation:
The "loop" command
This command is used to determine which board is potentially providing synchronizing for the system.
Syntax: loop <cr>
Where:
y: enables loop back,
n: disables loop back.
Status can be:
i: for an internal loop,
e: for an external loop,
c: to loop a specific trunk. To do this, trunk group number must be entered [from 1 to 23].
Examples:
(1)OXE0> loop 4 3 0 y e
to set up an external loop.
(1)OXE0> loop 4 3 0 y i
to set up an internal loop.
(1)OXE0> loop 4 3 0 y c 1
to set up a loop on a specific trunk (1 in the example).
The "loop" command
Syntax: loop <cr>
Where:
Status can be:
Examples:
tincho.rn
tincho.rn
