password for a 4038 IP phone
doum_DUP
Post by doum_DUP »
Hello
I have a 4038 who need a password for enter in parameters (i#), i have tried many (0000, 1234...) but i don't find.
I don't know the lenght of this password and if it use alpahabetic caracters.
Have you ever seen this problem?
brainwave
Re: password for a 4038 IP phone
Post by brainwave »
doum wrote:Hello
You may format the flash of 4018 set using the following procedure as stated below:
1) Connect a PC and 4018 in a HUB or switch, or cross cable
2) Change the IP address of your PC to 192.168.1.10
3) Unplug the power cable of faulty 4018 and press the keys i, 1,2 and 3 simultaneously
4) Plug the power cable now (with the i, 1,2,3 keys pressed)
5) Wait for the LED to glow and one the LED are off, stop pressing the keys i,1,2,3
6) From the PC telnet to faulty 4018 ( telnet 192.168.1.1)
7) You will get the prompt as NoePhone > now enter the following commands
8) config set x.x.x.x y.y.y.y z.z.z.z ( where x is the new IP address, y is the new subnet mask and z is the new default router address)
9) config tftp addr a.a.a.a (where a.a.a.a is the tftp ( logical main) address
10) You should get config OK as acknowledgement
Unplug the power, connect the Faulty 4018 in customer LAN and the connect the power again; it should come in-service with the current password.
Gr. Ben
doum_DUP
Post by doum_DUP »
I have tried but it doesn't work, i have to change the mode "static" to "dynamic" or "dynamic Alcatel", is it possible?
NoePhone > ipconfig
#ipconfig#
ip 192.168.92.250
router 192.168.92.11
mask 255.255.255.0
tftp 192.168.92.246
tftpport 192
cpu 192.168.1.6
mode static
vlan 4095
use_vlan no
ipconfig OK
best regards
doum_DUP
Post by doum_DUP »
I have find the solution:
config dhcp a (for Alcatel only)
Karel538
Post by Karel538 »
Try thales which is the default pass when the phone had encryption.
nperalta
Post by nperalta »
THALES is the password by default.
bye
Tele-Shop
Post by Tele-Shop »
My 4038's don't have the default password and when i telnet them (192.168.1.1) i dont get the NoePhone > prompt.
braveheartz
Post by braveheartz »
I have a NoePhone> prompt .. ... I already did the "reset flash" so it should be everything in default config or factory settings.
During the initial power-up of the ip phone via poe from a switch I pressed the # and i to interrupt the boot sequence and shows me a password request with a check on the upper left hand and an enter at the upper right hand corner
For the password ..
I tried 0000, 1234
I also tried "thales" and "THALES"(I pressumed the up arrow is the shift key)
... none works
My objective is to see the Menu settings. Please help ...
tgn
Post by tgn »
connect the phone to an oxe callserver where the noe password is off.
regards...
--- back to basics... focus your eyes on the essential things... ---
