Hi!!
I construct the call center.
but callserver incvisu log is indicated error logs below.
09/12/09 15:34:50 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 15:36:19 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 15:44:44 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 15:47:19 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 15:48:03 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 15:57:28 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:10:06 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:12:05 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:12:34 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:20:29 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:22:52 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
09/12/09 16:27:38 000001M|---/--/-/---|=3:4026=CSTA server : 2 type(15) - get bad data
I saw the few days ago. few day ago was random.
but today is indicated continue.
what happen is my callserver or call log?
pls answer my question.
incvisu error log [4026=CSTA server : 2 type(15) - get bad ]
MR_PT1
Re: incvisu error log [4026=CSTA server : 2 type(15) - get bad ]
Did you try the incinfo command? You can use this command to see the meaning of the incidents.
Well, for this incident 4026 will be showed:
CSTA server : P1 type(P2) - get bad data
P1 : server pid
P2 : data type
(CSTAINC_BAD_DATA)
The Call Handling sends wrong/corrupted data.
Unrecoverable error.
No operator action required.
P1 : server pid
P2 : data type
(CSTAINC_BAD_DATA)
thkim81
sure..
I know the incinfo.
but I don't know the resolve the problem.
Where is find the category or part in mgr for resolve the problem?
I know the incinfo.
zap_ldu
hello, you can solve this problem??? tks
Can you provide a tcpdump for a period of time when those incident happens ?
Sadim
Sadim
thkim81
Ok. I'll tcpdump when I figure out at problem.
Check /tmpd/csta_*.log
