Hello guys
I have a problem with Amix 4/4/4 board.I instaled it on a OXO (CPU 2) R4 ,the license is ok , the board is present and accepted but i can not use the analog user ports because those port are not present in subscribers list. The analog trunk ports and digital users ports are ok.
It could be something related to hardware problem(pin damage??)??
Until now i didn`t try to change the slot .Maybe someone ecountered this problem.....
Thank you in advance
Amix 4/4/4 board - analog user ports are not available
Re: Amix 4/4/4 board - analog user ports are not available
Hi there
I had a similar problem with an APA8 board. OMC showed as APA4 due to integrated circuit bad connected. Try to change this board too.
If you use a large rack you need to use amix board at slots 1,2,3, or 4.
I hope to help you.
Best regards.
I hope to help you.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Thank you for your reply.
Now i use medium rack and amix board is conected in slot 2.
I will try to change the slot from 2 to 4 and the if its not working i will send the board back for replacement
Hi Shadow
Try to change the board too. Or try to connect another kind of board in the same slot to see if the oxo understands the correct board.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Hi enio.eltz
That is a good ideea.In fact i will put APA 4 in that slot to see if it is properly recognized.
Thank you for your tips.
Best regards
Best regards
