INTIP CARD REBOOT ISSUE
bhavik_naik
Post by bhavik_naik »
My OXE working in ABC-F one of the INTIP keeps on rebooting ..what could be the problem...after looking at incidents ...we are not able to resove the same.....
Can someone gudie me...
Naik
Re: INTIP CARD REBOOT ISSUE
Post the incidents, the configuration of the INTIP and general architecture of your systems (IP addresses, etc). We are not psychic to just know what happens in your case.
egrep
Post by egrep »
the incidenc is important (incidenc 5857 Reason of Reboot).
Maybe the Logfiles File(s) from the INTIP are also important.
How to get that file:
cplstat *SHELF-ADRESS* *BOARD-ADRESS* (for example cplstat 2 6)
notice the ip Adress (for example 10.11.12.13)
then
tftp 10.11.12.13
bin
get README
quit
now you have README in your current directory (default should be /usr2/mtcl/)
now read that file:
cat README
you will see which logfiles has been created, and the creation time (if the INTIP was still in Service or has a time source)
now download the logfile (or files):
tftp 10.11.12.13
bin
get log0.txt
get log1.txt
and so on...
type
quit
now take a look at the look files (and post it/them here) ;-)
cat log0.txt
Many text, but there should be some interresting information like Keep Alive lost...
Good Luck
Return to “Hardware”
