6850 stuck in Vxworks mode, doesn't load MiniBoot
AcMe
Post by AcMe »
Posted this new topic 2/11 but it didn't show in forum?? Well, well, I try again.
The problem is that the switch hangs in vxWorks mode:
"U-Boot (6.3.4.265.R01) (for OS6400, OS6850, and OS6855 platforms) (Dec 15 2008 - 21:31:42)
MPC8247 Reset Status: External Soft, External Hard
MPC8247 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8247 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS6850 (Kite II)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
No environment variables found, using defaults
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: CF 64MB Firm: 20060729 Ser#: 2009B 0000479143
Type: Removable Hard Disk
Capacity: 62.5 MB = 0.0 GB (128000 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.3.4.265.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 865022 Bytes = 844.7 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Ethernet MAC address not copied to NV RAM
Loading .text @ 0x01000000 (1385008 bytes)
Loading .rodata @ 0x01152230 (275091 bytes)
Loading .data @ 0x011954c8 (118772 bytes)
Clearing .sbss @ 0x011b24c0 (1556 bytes)
Clearing .bss @ 0x011b3000 (1541436 bytes)
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0
## Starting vxWorks at 0x01000000 ..."
The next line is supposed to like something like this:
"ataDrv call. 0 1 24 24 621 0 0"
But this line never shows....
Any clue what to do next?
Sincerely,
Stefan
Re: 6850 stuck in Vxworks mode, doesn't load MiniBoot
I don't know what to do. You can try to exchanche the flash card with an other switch for finding the issue. Also I had have a similar issue (2 times): the power supply was the reason. You can exchange this.
But sometimes also an alcatel-switch goes damaged. Then you can use the lifetime warranty - this is an advanced replacement.
Do you know what was with the switch before the issue: does it work fine a long time or is it a new one? Was there a power interuption?
regards Silvio
AcMe
Post by AcMe »
Just before a reply was posted, I actually tried with a different powersupply!
Now the switch is back in business!
Thank you for the attention!
Stefan
