After the upgrade from R9.0 h130128b to h130134, I'm having problems to copy the database from the Main Call Server to PCS.
I tryed to launch the pcscopy command --> 1 - PCS Update --> after some seconds the message "End NOK: Restore on PCS failed" is showed.
When I launched the incvisu command was showed; 09/10/09 15:47:02 000001M|---/--/-/---|=3:0433=PCS 10.210.126.5: Database update: error 6 info 11.
Somebody have any idea about this?
PCS Database update error
Re: PCS Database update error
Well,
viewtopic.php?f=24&t=7308
Some R&D guy is going to RTFM for rhost/rlogin in next few months or this will not be solved.
One of many bugs in R9.
It was working in R9.0-h1.301-28-d. I think the bug is in patch h1.301-34...krzysioD wrote:Well,
You can test to add your main (and physical) CPU address in netadmin on PCS as hosts (Choice 9 if my memory is good).
Any hosts added by netadmin can use rhosts features normally (but I have not AS to test this actually).
G.
G.
I've thought so, but...
In latest patch there is a need to use vi editor and add some IPs by hand...
It's already added in netadmin on PCS. The settings before the upgrade are the same, but just don't work anymore. I will try to configure the PCS and maybe load the software again today.Gedeon wrote:You can test to add your main (and physical) CPU address in netadmin on PCS as hosts (Choice 9 if my memory is good).
G.
Thanks...
I did the configuration in the inactive partition and it's working again.
