Alcatel Lucent IP touch 4018 reseting
ehia
Post by ehia »
we are using oxo R7. We have 2 IP phones and sad to know everytime i connected the IP phone it always appear on the screen considering i setting up already the IP and tftp and subnet. same configuration with other IP 4018 that working now except with the IP.
1/5 Powered by WindRiver
2/5 Network Set up
3/5 Config Download
4/5 BInary Downlad
getting load
same found new version
getting code
getting data
5/5 connecting
reset please wait
then back to 1/5 so on and so for.
enio.eltz
Re: Alcatel Lucent IP touch 4018 reseting
Post by enio.eltz »
Hi Ehia
Did you see if you have software keys to run e-reflexes?
Best regards
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
TPI
Post by TPI »
try to disable the reset for update parameter under the user (user > TCP/IP user). We have had a customer that had some issues with 4018 phones rebooting like this, appeared to be a bad batch from ALU.
nperalta
Post by nperalta »
look the file
lanpbx.cfg
khodgson
Post by khodgson »
We have a problem like this seemingly with phones that have been plugged in not being able to find a licence - was told to wait 20 minutes or so. Noob question: do the phones have ROM that clears itself after a certain time period?
BigDaddy
Alcatel-Lucent IP Touch 4018: HELP
Post by BigDaddy »
I was wondering if there is a way to program the phone to force answer another caller's phone. How does one initiate the intercom feature?
morio
Post by morio »
its OXO right. are you using dhcp or static. if dhcp are you using the pbx dhcp or external? also you need to creat least one IP user
ebilo
Post by ebilo »
Sorry, I saw this thread..
Just want to ask where can I see the user > TCP/IP user? it is on the pressing "i" during reboot?
user > TCP/IP user is under mgr or omnivista
MGR
qReview/Modify: TSC IP Userqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Directory Number : 553737 x
x x
x Set Type + IPTouch 4038 x
x Voice Coding Algorithm + Without Compression x
x Terminal Ethernet Address : 00:80:9f:60:37:a6 x
x IP Address : 10.235.96.169 x
x IP Domain Number : 0 x
x Use of volume in system + YES x
x Reset For Update Authorized + YES x
x IP-Softphone Emulation + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
indeed the above is for OXE
