Ops Loading
sanjib
Ops Loading
Post by sanjib »
Hi all
Can anybody help me for ops loading in Rel 3.2 by ftp.
My MMSFD card is already faulty.
wait for ur reply.
Sanjib
lmartinez
Re: Ops Loading
Post by lmartinez »
hi, I think it's the same way you do in R8/R9
Use a FTP software like FTP commander, a transfer all the OPS file to the /usr4/BACKUP/OPS
Once you have the files on your CPU, use swinst to load it.
I hope a could help you.
Luis,
Gedeon
Re: Ops Loading
Post by Gedeon »
Sorry, no OPS directory in /usr4/BACKUP in this release.
If you don't have floppy, and if you don't have modification on hardware, only locks in software.mao, you can transfer the OPS files in /usr2/mtcl by FTP.
Before, I think wxhat you have a copy of your database, if you need restore in cas of problems.
After copy the OfferId.sw in /usr3/mao/software.new and run spadmin.
Select install a new file in menu and follow the instruction.
After, check that software.mao and OfferId.sw are the same file and the same what your new OPS file.
If you have modification in hardware, you can copy the new hardware.mao and OfferId.hw in /usr3/mao and manually add or delete ACT or boards in your database according with your new configuration.
Use checkdb to verify coherency and spadmin to check the Panic flag.
Shutdown is a good precaution to check if no problem in database.
It's the old method to manually install OPS. It's for ACSE not for beginner.
G.
Re: Ops Loading
Whoa.. 3.2...! I was not even born I think !
Re: Ops Loading
From R3 - can be used save&restore database from cpu disk.
From R3.2 - OPS can be loaded from cpu disk (/usr4/BACKUP/OPS).
briandang
Re: Ops Loading
Post by briandang »
HI! how can i download 4760i software in order to export OPS file?
give me the links to download thanks
briandang
Re: Ops Loading
Post by briandang »
thanks for your help,
i already download it.
in addition, thanks Frank for post Alcatel Document for us to download.
Thanks and regards
Brian,
Return to “Software Loading”
