I am deploying phones for a fire department.
They need to receive the caller ID even if it is secret.
The operator say the configure the T2 to do this.
When I trace the primary, I always see the caller/called number but it did not show on the phone screen.
As far as I know their is field in the trace for the secret option, do you know wich it is?
Is their something I must program in the oxe (r8) to reveal the number?
PS: unmasked numbers are shown correctly.
caller ID overdrive
Re: caller ID overdrive
About field:
you have f.e. "Calling number 01 81: 1234567890"
If caller order "secret identity" feature you will have "Calling number 01 a1: 1234567890"
81 (or a1) - we have 8 bits,
bits 7 and 6
00 presentation allowed
01 presentation restricted
10 number not availiable due to internetworking
11 reserved
bits 7 and 6
11 reserved
intheskin
Here what I found in my traces
a1 10100001
a3 10100011
80 10000000
81 10000001
If I take bit 7 and 6 (right to left, starting at 0), all have the value 10?
From the test I have made 8x is ID is clear, Ax is secret.
Could you explain me some more or maybe tell me if you have a "how to read traces for noobs"!
Anyway, thanks for the quick answer!
a1 10100001
a3 10100011
80 10000000
81 10000001
You need to order specific license from ALU, this licence is not covered by ACTIS.intheskin wrote:Is their something I must program in the oxe (r8) to reveal the number?
