hi guys,
I m trying to install office link driver for CDR info to alcatel oxo,
after install I have following message in log file..so need your helps..
what can I do for problem ?
Thu Aug 20 14:58:38 2009 ERROR 2640 AlcAHLDataLayer::Run() : Metering initialization error 2
Thu Aug 20 15:00:55 2009 INFO 1220 AlcAHLManagement::AlcAHLManagement : Creates AlcAHLDataLayer()
Thu Aug 20 15:00:55 2009 INFO 1220 AlcAHLMetering::initInterface : CoCreateInstance CAPService
Thu Aug 20 15:01:10 2009 INFO 1220 AlcAHLThread::startThread : Thread started
Thu Aug 20 15:01:26 2009 ERROR 1604 AlcAHLMetering::initInterface : Unable to create Ticket Collector
Thu Aug 20 15:01:26 2009 ERROR 1604 AlcAHLDataLayer::Run() : Metering initialization error 2
office link driver problem
- tot3nkopf
Re: office link driver problem
v.24 or ethernet? for ethernet connection between OLD and PCX I think you need a license.
on ethernet,
when I try on another pc its working,,I can see new xml file,,
I think problem about windows register, but I cant found anything..
See if you have write permissions in the directory where the OLD is installed.
Apparently the OLD is failing to generate the Ticket Collector.
Check the licenses, but I think if you do not have it the log shows a license error.
- giovanni.attolini
Check the configurantion file named OhlDriver.conf
Giovanni A. Attolini
- Jtmurphy76
Good day Enerkan.
Did you manage to resolve this issue.
I am experiencing the same, and have disabled the clients firewall and the necessary network checks have been completed.
