Omnivista NMS.
azcot
Omnivista NMS.
Guys where can I get good guide on using Omnivista 2500 / 2700 nms?. Help is in need as I'm new to network solution of Alcatel. Voice aok. TIa
cedric1
Re: Omnivista NMS.
if you need doc for ovista voice or data ?
voice = 4760 and there is dedicated forum for it.
Let me know if you need for date, I will send you a link with doc
cedric
cedric
azcot
Re: Omnivista NMS.
i need omnivista (nms) docs for data. as of now i managed to configure the switches so that my omnivista can discover it and configured the traps for my switches. But is it possible in my topology to add end devices such as snmp enabled linux pc, windows pc,,, etc.?
All I can see in the topology is the map or graphical view and connections of my switches. The switch icon goes red when the link is down and green when link is good. How about the end devices connected to the switch? Is this such limitation of software from alcatel?
cedric1
Re: Omnivista NMS.
Hello
You can add third party devices.
If you want to add link between switch and end device, try to use manual link fonction.
http://www1.alcatel-lucent.com/enterpri ... 3MCYWGI3GC
Cedric
Cedric
