hi
please tell me how can i insert the OPS files in vmware?
masoud.nouri@nuranetworks.com
Thanks alcatel unleashed and all users.
Vmware and OPS
Re: Vmware and OPS
Hi..
Use the FTP software to transfer the ops files to DHS3dyn/backup/ops and goto swinst restore the ops file from disk..finished..
cheers...
cheers...
ACSE Business R.9.x
Haroun_DUP
Re: Vmware and OPS
may be also transfert to /usr4/BACKUP/OPS
AND SWINST
OPS ADMIN
RESTORE FROM CPU DISC
AND SWINST
OPS ADMIN
swinstation
Re: Vmware and OPS
thank everybody for your help.i know about swinst and restore i want to know which program and how help me to do ftp?
Haroun_DUP
Re: Vmware and OPS
use any usualy ftp progrmam
or create a directory(ops for exemple) in C: and put your ops on
cmd
c:/cd..
cd..
cd:/ cd ops
under c:/ops tape
ftp ipadress of the oxe
loggin as mtcl
tape cd /usr4/BACKUP/OPS
DIR
if there are any ops file you should remove them : under Hyperterm or telnet oxe cd /usr4/ backup/ops
rm.*swk
rm.*hw
same .zip and .mao
on the ftp session
type Bin (transfert mode binary)
type put filename .swk
put filename.zip
put filename.mao
put file name.hw
after that use restore from swinst
other methode consiste to put them in /usr3/MAO
SMAE METHODE AS UP
after tansfering by ftp
go to oxe
cd /usr3/MAO
chmod filename.zip 664
SAME OPERATION FOR THE OTHER FILE
reboot
cmd
c:/cd..
cd..
cd:/ cd ops
under c:/ops tape
loggin as mtcl
DIR
rm.*swk
rm.*hw
same .zip and .mao
on the ftp session
put filename.zip
put filename.mao
put file name.hw
SMAE METHODE AS UP
go to oxe
cd /usr3/MAO
reboot
