IBS / DECT sets
rholubec
IBS / DECT sets
Have a large location with over 150 PWT users with over 30 IBS basestation spanning a 300,000 sqft. area. I am looking for a log for each of the IBS's giving me usage per IBS, I am looking for saturation stats.
rholubec
It is not "Topology" - it is "Traffic Observation" you needrholubec wrote:We have 4760 - everything but Topology, which application can I use to get preformance stats?
You can use "low-budget' end - terminal (VT-100) based "performance" application.
Login to OXE via telnet or on V.24 port then "cd /usr4/pmm" and run "obsappli".It is poorman's "Traffic Observation".Interface is like that of "mgr".You can print system reports or define your own.
Anyway, it uses the same system counters as 47600 "Traffic Observation" does.
Since you have the Past Time Performance lock, you can use the reporting application.
First, we need to turn on the counter collection. Open the 'Account/Traffic' application, then click on the parameters tab. Open the 'loading' area, click 'traffic observation', choose the appropriate selections for the Customer site & validate.
The counters won't be available until another synchronisation to the PCX, after this, you will be able to run reports from Omnivista
Hope this of some help
