Oxo cpu into gd board
zakk
Post by zakk »
Do you know if it is possible to load a oxo cpu with pc installer to convert it into a gd board ?
They seems to be very similar, with the right conbinaison of switch. I want to do some test with my vmware oxe.
Thank you for your help
Sorry my english and my strange question :))
Re: Oxo cpu into gd board
Stop posting the same all over the forum.
zakk
Post by zakk »
Sorry for multiple post, i have think that's not working....
And for my post: it is ok, i have convert it into a gd board.
thanks and great job. If you can would be nice to share the how to so others users can get the knowledge too.
knightr1der
Post by knightr1der »
i'm sure this has been covered before - tot3 mentioned something back in 2007 i'm pretty sure :?
murraya
Post by murraya »
I think you just change the dip switches and load the sotware, Same as you do to use the CS as a GD.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
murraya wrote:I think you just change the dip switches and load the sotware, Same as you do to use the CS as a GD.
Right.
Search function of this forum is also helpful.
zakk
Post by zakk »
Hi, tot3nkopf that's exactly what i have done. Move the switch to the same configuration of a GD board and using pc installer.
silves
Post by silves »
zakk wrote:Hello,
I get to load cpu boards like gd boards but only cpu-2 and 3. In cpu-1 is not possible, I thing
silves
Post by silves »
I get load OXO cpu´s like gd boads but only with cpu-2 and 3, not with cpu-1 board.
Return to “Software Loading”
