automated attendant
it2006z_DUP
automated attendant
Post by it2006z_DUP »
i have configured automated attendant as voice guide meassage then the caller dial the required internal extension after press 1
but after the message played and the caller press 1 and dial the extension
but the internal user doesn't response
i don't know where is the problem
can you help me
buraka
Re: automated attendant
Post by buraka »
Hi did you programming auto attendant before.?.if you firt programed can you look at the a lot of parameteres
it2006z_DUP
yes i programeed AA before here when the caller reach the AA and he can dial DTMF number he dial the extension number but oxe doesn't transfer the caller to the dialed number although the session still open between the caller and the oxe
do you understand me
i wish that
uduenas
Post by uduenas »
can you explain with an example please?
it2006z_DUP
problem was in dtmf key it must be differnet than the first digit of the internal user
examp dir no for user is 1001
and i was using dtmf key 1
so i change dtmf key to 9 and it was success
thanks very much for you
sadiseemi
Post by sadiseemi »
it2006z_DUP wrote: 10 Jun 2009 08:38 yes i programeed AA before here when the caller reach the AA and he can dial DTMF number he dial the extension number but oxe doesn't transfer the caller to the dialed number although the session still open between the caller and the oxe
i wish that
Helo sir
Can you share complete AA configuration like...external caller received welcome message and dail your extension voice guide .
Return to “Application”
