infocollect
deesinf
infocollect
Post by deesinf »
:D 1st i'm a new uers, i said hello for evry body in this forum, and i thank you for this prog i'm really need
tincho.rn
Re: infocollect
Post by tincho.rn »
As far as I remember, with new releases, infocollect is in the system. Just try to execute the command. Whats more, install the last patch for R9 that solves a well known problem in infocollect.
Finally you can download it from BPWS. I don't think we can upload the program here. Regards.
Re: infocollect
Search in the forum, the use and docus are around and well detailed
Re: infocollect
The latest version should be in this forum already...
Return to “Other Alcatel-Lucent tools”
