1.
I have a system setup in room management( mainly because of PMS limitations).
In each room i have one ip-phone and one analogue. The client wants the ip-phone to ring at the same time as the analogue, but i can not create a suite as i am not in Guest Management mode.
Can someone help with a possible solution
2.
Is it possible to have metering on internal calls ( extension to extension) , if possible how ?
Thanks in advance
Suite setup in room management & Internal Metering
- tot3nkopf
Re: Suite setup in room management & Internal Metering
Ideas:
1.
Incoming calls:
-use set supervision with ring on digital set supervising the analog set
-also tick take supervision at off hook on digital set parameters
Outgoing calls:
-from analog no problem
-force the digital set to substitute with the analog extension (you can use hotline feature -routing at off hook- for that - for immediate substitution)
2.
You need local calls metering license for that.
Regards.
1.
Incoming calls:
Outgoing calls:
2.
Regards.
Why can you not turn on Suite feature in the hotel parameters, reset the system and away you go. Create you GPINS create room extns, tie them together under Hotmenu and all good. Dont forget though once Suite feature is on every room will require a GPIN....
- tot3nkopf
He said he cannot due to PMS limitation.oldboy wrote:Why can you not turn on Suite feature in the hotel parameters, reset the system and away you go. Create you GPINS create room extns, tie them together under Hotmenu and all good. Dont forget though once Suite feature is on every room will require a GPIN....
whats the issue you can do everything through Hotmenu..no need at all for a PMS system
- tot3nkopf
tell that to a receptionist used only to make a check in on the front desk computer and he will hang youoldboy wrote:whats the issue you can do everything through Hotmenu..no need at all for a PMS system
