Hi all
On OXO system I have option to select number of digits that I will used
That is (2 or 3 or 4 digit numbering plan).
But I need 6 digits at least for numbering plan
Because my customer request are 6 digits for numbering plan
Please if any one knows how I can does that. Please tell me
Thanks and Best Regard
numbering plan
et
Re: numbering plan
OXO can support up to 8 digits in numbering Plans. Simply modify the required strokes in it.
samehit
Re: numbering plan
thank siret wrote:OXO can support up to 8 digits in numbering Plans. Simply modify the required strokes in it.
please tell me how I can modify required strokes
thanks and beast regard
et
Re: numbering plan
In Numbering Plans you can modify the "Function", "Begin", "End" and "Base" fields. Please try. After that, press "Modify" button, then OK.
gzi
Re: numbering plan
ET is right.
But I think an example is better than a raw explanation see it below:
First I assume that default numbering is 3 digits (which is OXO's default)
In numbering plan, modify the (or one of) subscriber line as follows:
Begin End Base
123xxx 123yyy 100
then click Modify
You can delete the other subscriber lines if exist or leave them as is.
ET is right.
Begin End Base
123xxx 123yyy 100
then click Modify
