OXE loading in SUN VirtualBox
ranlp
Post by ranlp »
I am trying to load an OXE R9 Blade Server on SUN VitualBox, the loading process it is ok, but when the system boots up, VirtualBox crashes when the Chorus emulation is started on OXE.
Any clues?
As anybody used it?
I am using Virtual Box instead of VMWare because it is free.
torrentula
Re: OXE loading in SUN VirtualBox
Post by torrentula »
vmware player is free, you can create vm's online too using easyvmx.com
Virtual box is nice, but I've had some problems with it.
fvelky
Post by fvelky »
Which version of VirtualBox are you using? I have version 3.0.4r50677 with OXE version 9.x, and this work fine.
Yes problems like what torrentula? I'm willing to change VMWare by Virtualbox because of costs...but wouldn't like to face problems or add time costs which would be a lost for the moment...
torrentula
I don't remember the problems I had with virtual box, been too long ago.
I switched from Virtual Box to VmWare a long time ago.
Like it is said here, the player is free.
Yes but you still need the VMWare to create the image.
Gedeon
Post by Gedeon »
Vmware server 1.0.9 is free, also vmware 2.0.
You can create VM like you want, and OXE work fine with vm 1.0.9 (I prefer the release to 2.0).
It's free from more 1 year.
G.
I use VmWare server 2.0 , too.
outerman8651
Post by outerman8651 »
Can create virtual OXE with Oracle virtualBox?
Return to “Software Loading”
