hello everybody
i need please cable console pinouts for connect my switch with pc
[ rj45 to db9]
please it's high urgent
thanks
help in omniswitch 6800
cedric1
Re: help in omniswitch 6800
hello
this is connecter cable map I have from alcatel-lucent.
Side on rj45 is already connected.$
cedric
cedric
benny
Simply use the connector which was provided with the switch + a straight-through network cable.
-b
-b
Hi Cedric, hope you still on the forums!
I need an understandable drawing please to make my own console cable. I have a normal Type A RJ45 cable, I cut the one end of, and want to solder in the correct colour match cables to the db9 connector. Kindly explain properly which goes where ?
Loucouss
Hey gbrits, I'm also trying to do so but note that cedric1 posted that a very long time ago. I followed this one it works but I cannot send any input, I might be wrong somewhere...
Link http://4.bp.blogspot.com/_Fduwa95b3Ac/T ... onsole.jpg
Hi !
This is the drawing I used as well, and it also did not work
Loucouss
I received datas with my scheme but cannot send it... I also bought the Startech DB9 adapter to match with Cedric's files but I does not work either.
I have an Alcatel omniswitch 6400-24
