OXO User Permisions
samehit
OXO User Permisions
Post by samehit »
Hi all
OXO set permisions:
I want to privent determine sets to get
outgoing calls (internal & external)
that mens set receive calls only
but this set can to call with special sets (internal)
example: (expect sinario)
set 140 used as receiver set for calls
set 140 can only to call with 150 and 151 sets
thank you
mavijitr_DUP
Re: OXO User Permisions
Post by mavijitr_DUP »
In my opinion, we can achieve this by introducing hotline feature. You can give only one extension number in the hotline field.
I have tested the following via configuration, you can group this two extension and give the group number in the hot line field (select immediate).
user--> details--> Misc--> Hotline.
Select Immediate and introduce the group number.
function description:
The moment the user lift the telephone handset it rings on the set 150 and 151 as grouped in the hunting group.
Vijay
samehit
Post by samehit »
mavijitr wrote:Hi,
Vijay
thank you for your help
but I want to know if I can to privent this set to do internal call expect 150 and 151 in this way
mavijitr_DUP
The hotline feature "Immediate" does not allow the user to dial any other extension. The user gets ring back tone the moment he lifts (off-hook) the hand set. So, there is no possibility to dial any internal extensions other than 150 & 151
Vijay
Return to “Configuration”
