Conection EMTL trunk to PLC ( eksternal pabx )
mulyadi
any one can help me.
i have problem in my site that is when i conneted to PLC ( external pabx ) using 4 wire EMTL
1. my Emtl trunk can`t communicated with 4 wire using EMTl to PLC but PLC can comunicate with alcatel.
2. i suspect the EMTL can`t send signal to PLC pabx, any body know where to know signaling 4 wire EMTL card ?
Tks before
Mlyta
Tks before
Mlyta
Gedeon
Re: Conection EMTL trunk to PLC ( eksternal pabx )
With 2 wireds, the signalization is in 50Hz or Frequency (ie : Q23 or 2280Hz)
With 4 wireds, you are 2 solutions :
- 2 wireds for voice and 2 for signalization (E&M)
- 4 wireds for voice and 2 for signalization (E&M or Frequency) (it's not really 4 wireds, but an usually language error)
The first step is to determine how many wired you have really, 2 or 4 or 6
The second the protocol to use (peer or master/slave)
The third the signalization (50Hz, E&M, Q23, 2280Hz, etc..)
And tempos between the two systems.
A good method is to make a loop on local board, after on remote system without the remote board, and the same thing to the remote system. If your two connexions are OK, you can connect EM -> REC, REC->EM, and signalization if necessary.
And after, it's "just" a protocol configuration...
G.
G.
mulyadi
hai Ged..
here is my specific connection :
1. my real wire using 6 wire.
2. where menu i can find set parameter master/slave ? ( in trunk category )
this my configuration :
┌─Consult/Modify: Trunk Groups──────────────────────────────────────────
│ Node Number (reserved) : 104
│ Trunk Group Id : 1048
│ Trunk Group Type + LIA
│ Trunk Group Name : EMTL
│ UTF-8 Trunk Group Name : ---------------------------------
│ Number Compatible With : -1
│ Remote Network : 15
│ Shared Trunk Group + False
│ Special Services + Nothing
│ Node number : 4
│ Transcom Trunk Group + False
│ Auto.reserv.by Attendant + False
│ Overflow trunk group No. : -1
│ Tone on seizure + False
│ Paging Trunk Group + False
│ Paging Table Id : -1
│ Paging Signalization + NDDI
│ Security Patrol + False
│ Prefix Sending + False
│ Number Of Digits To Send : 0
│ T.line Calling last dig.length : 0
│ auto.DTMF dialing on outgoing call + NO
│ Public Network Category : 0
│ Implicit Priority
│ Activation mode : 0
│ Priority Level : 0
│ Preempter + NO
│ Incoming calls Restriction categ. : 10
│ Outgoing calls Restriction categ. : 10
│ CUG List Number : -1
│ CUG Preferential : -1
│ CUG Outgoing Access + False
│ CUG Incoming Access + False
┌─Consult/Modify: Trunk──────────────────────────────────┐
│ Node Number (reserved) : 104 │
│ Trunk Group Id : 1048 │
│ Instance (reserved) : 1 │
│ Physical Address : 0-19-0 │
│ Trunk Category Id : 15 │
│ Directory Name : -------- │
│ Trunk Routing Number : -------- │
│ Channel Specialization + Mixed │
│ Trunk Number : 120 │
│ Data Transparency + NO │
┌─Consult/Modify: Trunk Category─────────────────────────────────────────────┐
│ Connection Category Id : 5 │
│ Trunk Type + IACE (Status Line TL) │
│ Signalling Type + Not Relevant │
│ Waiting Guide + True │
│ Overflow Timer on No Reply : 300 │
│ Overflow Timer on Waiting : 300 │
│ Tie Line Trunks │
│ Type of Numbering + MF Q23 │
│ Delay Before Availability : 3 │
│ Delay Between Digits on Receiving : 150 │
│ Dial Tone Connection + False │
│ Ringback Tone Connection + True │
│ Incoming DTMF Received + False │
│ Line Type + Short line │
│ Digit Pulse Duration (ms) : 50 │
│ Digit Pause Duration (ms) : 50 │
│ 2 or 4 Voice Wires + 4 Wires │
│ End of Selection + NO │
│ IACE Tie Line Trunks │
│ Outgoing Seizure Acknowledgment + YES │
│ Incoming Seizure Acknowledgment + YES │
│ Seizure Acknowledgment Timer : 20 │
│ Delay Before Sending Seizure Ack : 2 │
│ Dial Tone Detection + False │
│ Default Transmission + False │
│ Delay Before Outdialling : 5 │
│ Receiving the Dialling + True │
│ Delay Between Digits on Sending : 10 │
│ Busy Tone Connection + False │
│ Send Reply + False │
│ Reply by Pulse + False │
│ Delay Waiting for Reply : 0 │
│ ITTR feature / DC5A Inverted + False │
│ Controlled Release + True │
│ Release Acknowledge Timer : 16 │
│ Input Output Level + Users │
│ Trunk Type + Loop │
│ Paging + False │
│ Loop Feeding Signal Break Time : 20 │
│ Loop Feeding Sign.Make Time : 20 │
┌─Consult/Modify: Board──────────────────────────────────────────────┐
│ Shelf Address : 0 │
│ Board Address : 19 │
│ Interface Type + EMTL │
│ Virtual board + NO │
│ Serial number : -------------- │
│ Usage State + Active │
│ Operational State + Enabled │
│ Main/Standby State + Main (Master) │
│ Number Of Sets Being Connect. : 1 │
│ Country Protocol Type + Default │
│ Send Init Dynamic Msg + False │
│ Param By Default + True │
│ Incidents Teleservice + YES │
│ Tone on Board + R2 Tone │
Rgds
│ Node number : 4
│ Implicit Priority
│ Preempter + NO
│ Tie Line Trunks │
│ Paging + False │
Rgds
Gedeon
With this configuration, it's not possible to make a call to the remote PBX.
Outgoing Seizure Acknowledgment + YES ==> depend of distant configuration
Incoming Seizure Acknowledgment + YES ==> I suppose it's OK if incoming call are working
Default Transmission + False ==> you can test with true if distant configuration is not OK
G.
G.
mulyadi
Hai G,
I already set and running but if I call to remote pabx, a called number ( extention ) can heard me but I can`t heard what he says ? do you have experience like this ?
it`s programed capture.
lqConsult/Modify: Trunk Categoryqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Node Number (reserved) : 104 x
x Instance (reserved) : 1 x
x Trunk Category Id : 15 x
x x
x Connection Category Id : 5 x
x Trunk Type + IACE (Status Line TL) x
x Signalling Type + Not Relevant x
x Waiting Guide + True x
x Overflow Timer on No Reply : 100 x
x Overflow Timer on Waiting : 100 x
x x
x Tie Line Trunks x
x x
x Type of Numbering + D 66 33 x
x Delay Before Availability : 3 x
x Delay Between Digits on Receiving : 150 x
x Dial Tone Connection + True x
x Ringback Tone Connection + True x
x Incoming DTMF Received + True x
x Line Type + Short line x
x Digit Pulse Duration (ms) : 50 x
x Digit Pause Duration (ms) : 50 x
x 2 or 4 Voice Wires + 4 Wires x
x End of Selection + NO x
x x
x IACE Tie Line Trunks x
x x
x Outgoing Seizure Acknowledgment + NO x
x Incoming Seizure Acknowledgment + NO x
x Seizure Acknowledgment Timer : 20 x
x Delay Before Sending Seizure Ack : 2 x
x Dial Tone Detection + True x
x Default Transmission + False x
x Delay Before Outdialling : 5 x
x Receiving the Dialling + True x
x Delay Between Digits on Sending : 10 x
x Busy Tone Connection + True x
x Send Reply + False x
x Reply by Pulse + False x
x Delay Waiting for Reply : 0 x
x ITTR feature / DC5A Inverted + False x
x Controlled Release + True x
x
rgds
MlY
x x
x x
x x
x Tie Line Trunks x
x x
x x
x x
x
rgds
MlY
ManIshq
Hi All..
We have Alcatel-Lucent OmniPCX Enterprise and wanted to connect it with another PABX on analog link. The EMTL cards of this OmniPCX gives -48Volt on 4a and 0 Volt on 4b pin on MDF.
When we try to check voltage seizure by inter-connecting 4a and 4b, we get busy LED (on EMTL) but only for upto three ports. For rest of three ports, we are not getting the Busy LED.
Please help.
Please help.
What?
You'd better hire someone with some knowledge and experience.
We're here to help you in your efforts, not to do your job instead of you.
https://www.alcatelunleashed.com/viewto ... 125#p94125
Without knowledge, it will be areal headache for you ; some config to manage, some hardware(jumpers) to play with, and lots doc to read
protocol should be the same as first challenge.
is it mandatory to use such as obsolete tech
ManIshq
Hi All,
We have many M/s KAREL make and M/s MATRIX make PABX installed at various locations. Hence, we want to use those idle PABX.
This Alcatel shall connect with those PABX using Power Line Carrier Communication link (Trunk Line) using DTMF/Pulse Dialing Mode.
The Jumper Setting on EMTL card is now resolved provided xi03, xi04, xi05, & xi06.
We are using 6 wire communication- E, M, Tx, Tx1, Rx & Rx1.
So my queries reduce to:-
1) What shall be the jumper settings for xi03, xi04, xi05, & xi06?
2) How to change Number of Sets connected?
3) How to change Main/StandBy State?
x x
x Node Number (reserved) : 14 x
x Shelf Address : 0 x
x Board Address : 4 x
x x
x Interface Type + EMTL x
x Virtual board + NO x
x Usage State + Active x
x Operational State + Enabled x
x Main/Standby State + Standby (Slave) x
x Number Of Sets Connected : 5 x
x Country + Default x
x Send Init Dynamic Msg + False x
x Default Param + True x
x Incidents Teleservice + YES x
x Tone on Board + R2 Tone x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
x x
x x
x x
note local users should seize LOCAL trunk group ( in my case trunkgp N°4
parameters for node 6
board
Node Number (reserved) : 6 x
x Board Address : 3 x
x x
x Serial number : -------------- x
x Operational State + Disabled x
x Main/Standby State + Main (Master) x
x Number Of Sets Connected : 4 x this is the number of trunk created
x Country Protocol Type + Default x
x Incidents Teleservice + NO x
trunkgroup(local)
x Trunk Group ID : 4 x
x x
x Trunk Group Type + LIA x
x Trunk Group Name : AMM 8 x
x UTF-8 Trunk Group Name : AMM 8 x
x Number Compatible With : -1 x
x Remote Network : 15 x
x Shared Trunk Group + False x
x Special Services + Nothing x
x Node number : 6 x
x Transcom Trunk Group + False x
x Auto.reserv.by Attendant + False x
x Overflow trunk group No. : -1 x
x Tone on seizure + True x
x Paging Trunk Group + False x
x Paging Table ID : -1 x
x Paging Signalization + NDDI x
x Security Patrol + False x
x Send Prefix + False
Number Of Digits To Send : 6 x
x .line Calling last dig.length : 0 x
x DTMF dialing on outgoing call + NO x
x Public Network COS : 0 x
x x
x Implicit Priority x
x x
x Activation mode : 0 x
x Priority Level : 0 x
x x
x Preempter + NO x
x ncoming calls Restriction COS : 10 x
x utgoing calls Restriction COS : 10
regional parameters for tkgp 4
eview/Modify: Trunk Groupqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Public Network Ref. : ------ x
x VG for non-existent No. + YES x
x Entity Number : 0 x
x Supervised by Routing + NO x
x VPN Cost Limit for Incom.Calls : 0 x
x Immediate Trk Listening if VPNCall + YES x
x VPN TS % : 50 x
x CSTA-Monitored + NO x
x Max.% of trunks out CCD : 0 x
x Ratio analog.to ISDN cost : ------ x
x TS Distribution on Accesses + YES x
x Quality profile for voice over IP + Profile #1 x
x IP Compression Type + Default x
x Use of volume in system + YES x
x Announcement for dial tone + NO x
x Announcement for Ring tone + NO x
x Private to Public Overflow + YES x
x End-to-end dialing + NO x
x DTMF end-to-end signal. + NO x
x TS Permanently assigned + YES x
x Min. No. of digits on seize : 0 x
x Signal.with access code + NO x
x Trunk group used in DISA + NO x
x DISA Secret Code : ---- x
x Routing To Manager + NO x
x Redirection For ACD (Dissuasion) + NO x
x DTO joining + NO x
x Automated Attendant + NO x
x Calling party Rights COS : 0 x
x Number To Be Added : -------- x
x Access Cluster ID : -1 x
x Priority of Call + NO x
x COS Restrictions - Barring mode + Not Restricted / Not barred x
x ARS Class of service : 31
TRUNKS
lq[ 4 ] Instances: Trunkqk
x x
x -> 0-3-0 x
x 0-3-1 x
x 0-3-2 x
x 0-3-3 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqj
HERE YOU CAN CHANGE /ADD TRUNKS (sets connected)
lqReview/Modify: Trunkqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Node Number (reserved) : 6 x
x Physical Address : 0-3-0 x
x x
x Trunk COS : 15 x
x Directory Name : -------- x
x Trunk Routing Number : -------- x
x Channel Specialization + Comb / Mixed x
x Trunk Number : 90 x
x Data Transparency + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
TRUNK COS =15
x Trunk COS : 15 x
x x
x Connection COS : 5 x
x Signaling Type + Not Relevant x
x Overflow Timer on No Answer : 300 x
x Overflow Timer on Waiting : 300 x
x x
x Tie Line Trunks x
x x
x Type of Numbering + MF Q23 x
x Delay Between Digits on Receiving : 40 x
x Line Type + Long line x
x Digit Pulse Duration (ms) : 60 x
x Digit Pause Duration (ms) : 40 x
x 2- or 4-Wire Voice + 2-Wire x
x x
x x
x Outgoing Seizure Acknowledgment + YES x
x Incoming Seizure Acknowledgment + YES x
x Seizure Acknowledgment Timer : 30 x
x Delay Before Sending Seizure Ack : 10 x
x Dial Tone Detection + False x
x Delay Before Outdialing : 5 x
x Receiving the Dialing + True x
x
Busy Tone Connection + False x
x Send Reply + True x
x Reply by Pulse + True x
x Acknowledge Release Timer : 16 x
x Input Output Level + Tie Line x
x Trunk Type + Loop x
x Paging + False x
x Loop Feeding Signal Break Time : 20 x
x Loop Feeding Sign.Make Time : 20
remote trunk should be creted in the local node even if it exists physiclly in node 8
x Trunk Group ID : 3 x
x x
x Trunk Group Name : TSS 6 x
x UTF-8 Trunk Group Name : TSS 6 x
x Node number : 8 x
x Tone on seizure + False x
x x
x x
x x
x Preempter + NO x
x utgoing calls Restriction COS : 10 x
x x
TRUNKGP SEIZE
Review/Modify: Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : 65 x
x x
x Prefix Meaning + Professional trunk seize x
x Prefix Information : 4 x
x Private Route type + False x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
board
x x
trunkgroup(local)
x x
x Node number : 6 x
x x
x x
x x
x Preempter + NO x
x x
x VPN TS % : 50 x
TRUNKS
x x
x -> 0-3-0 x
x 0-3-1 x
x 0-3-2 x
x 0-3-3 x
x x
x x
x x
x Trunk COS : 15 x
x x
TRUNK COS =15
x Trunk COS : 15 x
x x
x x
x Tie Line Trunks x
x x
x x
x x
x
x Paging + False x
x x
x Node number : 8 x
x x
x x
x x
x Preempter + NO x
x x
TRUNKGP SEIZE
x x
x Number : 65 x
x x
x x
