OXO Release 7 with ACD - Calls with none DDI to ACD
tomtom76
Post by tomtom76 »
I have the following problem on a OXO Release 7 with ACD.
ACD works on dialing the main number + 10
So 0660 4711-10 and the call is in acd.
Now all calls to 0660 4711 should be directly routed to the ACD and not to the Attendand Group
How could i make this?
thank you very much
Re: OXO Release 7 with ACD - Calls with none DDI to ACD
In the same way you routed the +10 number.
selectt_DUP
Post by selectt_DUP »
in the ACD configuration - line paramaters - "call ending in xyz" - send to group 1 of ACD.
Return to “MAIN”
