Download latest code?
Locked
rjmeredeth_DUP
Post by rjmeredeth_DUP »
Anyone know where I can download the latest(ver3.4) Omnivista 2520 install ISO. I have my SN and license, I just need the iso.
rjmeredeth_DUP
Re: Download latest code?
I have looked on the mysupport site and I have code for everything else, just not OV2520 or OV2730.
I can see both at the mySupport-site.
2520 = Single User (BSU)
2540 = Multi User (BMU)
for both you have to take 2500-file for windows: OmniVista 2500 BSU/BMU 3.4 for Windows (173.0M)
Also 2730 is visible: OmniVista 2730 PolicyView 3.4 for Windows,Solaris and Linux (159.0M)
Why don't you use 3.4.2? Update from 3.x is for free.
rjmeredeth_DUP
silvio wrote:I can see both at the mySupport-site.
Well that tells me what I need to know. That it should be in there. I'll contact support.
silvio wrote:Why don't you use 3.4.2? Update from 3.x is for free.
I'd love to, but I can't get ANY of them :D
I've attached a screen shot. Am I in the right place?
It's funny :-)
I can see a lot more than you. You are at the right place.
So you should contact Alcatel-support indeed....
good luck
Locked
Return to “Omnivista”
