how to start with a OXO?
wongfu
Post by wongfu »
Dear all,
Please help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!
I bought an OXO with CPU-1 from ebay, but I have no idea how to start with it? I was trained for OXE. I had tried to connect the console cable of OXE to the config port of the CPU-1, but I see nothing. So that I don't know the CPU-1 is a faulty module or the config cable not work.
Anyone can teach me how can I configure the OXO and know the CPU-1 is faulty or not.
Many Many Thanks
Re: how to start with a OXO?
You need OMC software in order to be able to config OXO.
If you are educated in OXE you can flash your CPU as GD and use the shelf as an OXE MG.
Regards.
wongfu
Post by wongfu »
How can I get the OMC and how to connect the OXO to the OMC?
Many thanks
Contact a local Alcatel reseller for that.
Regards.
wongfu
Post by wongfu »
thz.......could you kindly advice the full name of OMC?
et
Post by et »
Office Management Console (OMC) actually version: OMC700/23.1a.
wongfu
Post by wongfu »
thz. :)
dualcom
Post by dualcom »
For a CPU-1 normally will be running a version 2.0 and PM5 R210 44.0 is the best PM5 for this version.
Return to “Beginner's questions about the OmniPCX OFFICE”
