OXO with ISVPN
Pooja Ramchurn
OXO with ISVPN
Post by Pooja Ramchurn »
All my OXO PABX (version 5.1) have ISVPN enabled. Some of the PABX within the network are able to see the information of the caller but others cannot. The UUS allowed feature is enabled.Is there any special configuration? Can you please let me know what else should be configured?
Re: OXO with ISVPN
May be UUS forbiden in some PTT system (ask providers)?
Pooja Ramchurn
Re: OXO with ISVPN
already checked with the providers and they have nothing special to activate in their configuration.
Re: OXO with ISVPN
Check with trace tools - UUS sending and receiving.
Pooja Ramchurn
Re: OXO with ISVPN
can you please explain how it should be done and with which trace tools?
et
Re: OXO with ISVPN
Post by et »
In OMC when you online with OXO - in section Tools - OSC tool/ ISDN trace.
Pooja Ramchurn
Re: OXO with ISVPN
thanks! Got the following traces, for incoming call and outgoing call. The only difference i observed is that the 0x7EUser-User:04.
Can you please tell me, based on the trace, where the problem might be?
Thanks for your help!
ISDN3_00005 13/03 16:32:53 RX d_channel: 26 (S:00 T:127) payload: (38) 08 01 13 05 A1 04 03 80 90 A3 18 01 89 6C 09 21 81 32 30 36 34 30 31 37 70 05 81 37 34 39 31 7D 02 91 81 7E 01 04
0x05 SETUP Ref: O,19
ie 0xA1 Sending complete
ie 0x04 Bearer capability: 80 90 A3
Coding: CCITT standardized
Information transfer capability: Speech
Transfer mode: Circuit mode
Transfer rate: 64 Kbit/s
User info layer 1: G.711 A-law
ie 0x18 Channel identification: 89
Interface identifier: Implicit
Interface type: Basic
Indicated channel: Exclusive
D-channel identified: Yes
Information channel selection: B1 channel
ie 0x6C Calling party number: 21 81 32 30 36 34 30 31 37
Number type: National number
Numbering plan: ISDN/Telephony(CCITT Recommendation E.164/E.163)
Presentation: presentation allowed
Screening: user-provided, verified and passed
Number: 2064017
ie 0x70 Called party number: 81 37 34 39 31
Number type: Unknown
Number: 7491
ie 0x7D High layer compatibility: 91 81
ie 0x7E User-user: 04
ISDN3_00006 13/03 16:32:53 TX d_channel: 26 (S:00 T:000) payload: (4) 08 01 93 02
0x02 CALL_PROCEEDING Ref: D,19
ISDN3_00008 13/03 16:32:53 TX d_channel: 26 (S:00 T:000) payload: (7) 08 01 93 01 7E 01 04
0x01 ALERTING Ref: D,19
SAN_00011 at line 7932 "depub_aels"
on 13.03 at 16:32:55 (1738219892)
info : FFFF FFFF 0000 0000 0000 0000 0000 0000
ISDN3_00031 13/03 16:33:31 TX d_channel: 26 (S:00 T:000) payload: (29) 08 01 15 05 04 03 80 90 A3 18 01 83 70 08 81 32 30 36 34 30 31 37 7D 02 91 81 7E 01 00
0x05 SETUP Ref: O,21
ie 0x18 Channel identification: 83
Indicated channel: Preferred
D-channel identified: No
Information channel selection: any channel
ie 0x70 Called party number: 81 32 30 36 34 30 31 37
Number: 2064017
ie 0x7E User-user: 00
ISDN3_00032 13/03 16:33:31 RX d_channel: 26 (S:00 T:000) payload: (7) 08 01 95 0D 18 01 89
0x0D SETUP_ACK Ref: D,21
ISDN3_00033 13/03 16:33:31 RX d_channel: 26 (S:00 T:000) payload: (4) 08 01 95 02
0x02 CALL_PROCEEDING Ref: D,21
ISDN3_00034 13/03 16:33:32 RX d_channel: 26 (S:00 T:000) payload: (7) 08 01 95 01 7E 01 04
0x01 ALERTING Ref: D,21
ISDN3_00035 13/03 16:33:35 RX d_channel: 26 (S:00 T:000) payload: (12) 08 01 95 07 29 06 09 03 0D 10 1C 00
0x07 CONNECT Ref: D,21
ie 0x29 Date/time: 09 03 0D 10 1C 00
ISDN3_00038 13/03 16:33:39 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 15 45 08 02 85 90
0x45 DISCONNECT Ref: O,21
ie 0x08 Cause: 85 90
Class: Normal event
Value: Normal release
ISDN3_00039 13/03 16:33:40 RX d_channel: 26 (S:00 T:000) payload: (4) 08 01 95 4D
0x4D RELEASE Ref: D,21
ISDN3_00040 13/03 16:33:40 TX d_channel: 26 (S:00 T:000) payload: (4) 08 01 15 5A
0x5A RELEASE_COMP Ref: O,21
SIG SAN_00042 at line 1092 "l1_com.c"
on 13.03 at 16:33:39 (1738221400)
info : 0000 0000 0000 0008 0000 0D02 0000 0000
ISDN3_00053 13/03 16:34:12 TX d_channel: 26 (S:00 T:000) payload: (19) 08 01 16 05 04 03 80 90 A3 18 01 83 7D 02 91 81 7E 01 04
0x05 SETUP Ref: O,22
ISDN3_00059 13/03 16:34:13 RX d_channel: 26 (S:00 T:000) payload: (11) 08 01 96 0D 18 01 89 1E 02 82 88
0x0D SETUP_ACK Ref: D,22
ie 0x1E Progress indicator: 82 88
Progress: In-band information or appropriate pattern now available
ISDN3_00060 13/03 16:34:13 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 34
0x7B INFORMATION Ref: O,22
ie 0x70 Called party number: 81 34
Number: 4
ISDN3_00061 13/03 16:34:14 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 36
ie 0x70 Called party number: 81 36
Number: 6
ISDN3_00062 13/03 16:34:14 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 36
Number: 6
ISDN3_00063 13/03 16:34:14 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 33
ie 0x70 Called party number: 81 33
Number: 3
ISDN3_00064 13/03 16:34:15 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 36
Number: 6
ISDN3_00065 13/03 16:34:15 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 30
ie 0x70 Called party number: 81 30
Number: 0
ISDN3_00066 13/03 16:34:15 TX d_channel: 26 (S:00 T:000) payload: (8) 08 01 16 7B 70 02 81 30
Number: 0
ISDN3_00067 13/03 16:34:15 RX d_channel: 26 (S:00 T:000) payload: (4) 08 01 96 02
0x02 CALL_PROCEEDING Ref: D,22
ISDN3_00068 13/03 16:34:16 RX d_channel: 26 (S:00 T:000) payload: (4) 08 01 96 01
0x01 ALERTING Ref: D,22
Pooja Ramchurn
Re: OXO with ISVPN
I have sent you traces from both PABXs from where the calls were made:
ISDN3_00052 13/03 16:20:17 TX d_channel: 50 (S:00 T:000) payload: (41) 08 02 00 41 05 04 03 80 90 A3 18 01 A3 6C 09 21 80 32 30 36 34 30 31 37 70 08 81 36 32 32 37 34 39 31 7D 02 91 81 7E 01 04
0x05 SETUP Ref: O,65
ie 0x18 Channel identification: A3
Interface type: Primary rate
ie 0x6C Calling party number: 21 80 32 30 36 34 30 31 37
Screening: user-provided, not screened
Number: 2064017
ie 0x70 Called party number: 81 36 32 32 37 34 39 31
Number: 6227491
ISDN3_00053 13/03 16:20:17 RX d_channel: 50 (S:00 T:000) payload: (10) 08 02 80 41 0D 18 03 A9 83 84
0x0D SETUP_ACK Ref: D,65
ie 0x18 Channel identification: A9 83 84
Channel type: B-channel units
Channel number: 0x04
ISDN3_00054 13/03 16:20:17 RX d_channel: 50 (S:00 T:000) payload: (5) 08 02 80 41 02
0x02 CALL_PROCEEDING Ref: D,65
ISDN3_00055 13/03 16:20:19 RX d_channel: 50 (S:00 T:000) payload: (13) 08 02 80 41 45 08 02 80 A2 1E 02 82 88
0x45 DISCONNECT Ref: D,65
ie 0x08 Cause: 80 A2
Class: 1
Value: No channel available
ISDN3_00056 13/03 16:20:20 TX d_channel: 50 (S:00 T:000) payload: (9) 08 02 00 41 4D 08 02 81 90
0x4D RELEASE Ref: O,65
ie 0x08 Cause: 81 90
Class: Normal event
ISDN3_00057 13/03 16:20:20 RX d_channel: 50 (S:00 T:000) payload: (5) 08 02 80 41 5A
0x5A RELEASE_COMP Ref: D,65
ISDN3_00354 13/03 16:28:11 RX d_channel: 50 (S:00 T:000) payload: (41) 08 02 74 10 05 A1 04 03 80 90 A3 18 03 A9 83 85 6C 09 21 83 36 32 32 37 34 39 31 70 05 81 34 30 31 37 7D 02 91 81 7E 01 00
0x05 SETUP Ref: O,29712
ie 0x18 Channel identification: A9 83 85
Channel number: 0x05
ie 0x6C Calling party number: 21 83 36 32 32 37 34 39 31
Screening: network provided
Number: 6227491
ie 0x70 Called party number: 81 34 30 31 37
Number: 4017
ISDN3_00355 13/03 16:28:11 TX d_channel: 50 (S:00 T:000) payload: (5) 08 02 F4 10 02
0x02 CALL_PROCEEDING Ref: D,29712
ISDN3_00356 13/03 16:28:11 TX d_channel: 50 (S:00 T:000) payload: (8) 08 02 F4 10 01 7E 01 04
0x01 ALERTING Ref: D,29712
ISDN3_00357 13/03 16:28:13 TX d_channel: 50 (S:00 T:000) payload: (16) 08 02 F4 10 07 4C 09 21 80 32 30 36 34 30 31 37
0x07 CONNECT Ref: D,29712
ie 0x4C: 21 80 32 30 36 34 30 31 37
ISDN3_00358 13/03 16:28:14 RX d_channel: 50 (S:00 T:000) payload: (5) 08 02 74 10 0F
0x0F CONNECT_ACK Ref: O,29712
ISDN3_00359 13/03 16:28:25 TX d_channel: 50 (S:00 T:000) payload: (9) 08 02 F4 10 45 08 02 85 90
0x45 DISCONNECT Ref: D,29712
Class: Normal event
ISDN3_00360 13/03 16:28:26 RX d_channel: 50 (S:00 T:000) payload: (5) 08 02 74 10 4D
0x4D RELEASE Ref: O,29712
ISDN3_00361 13/03 16:28:26 TX d_channel: 50 (S:00 T:000) payload: (5) 08 02 F4 10 5A
0x5A RELEASE_COMP Ref: D,29712
borpas
Re: OXO with ISVPN
Post by borpas »
having the same problem, sending UUS at connect-time with encoding 0x00, get alerting telling me encoding is 0x04.
Is this a configuration or licensing problem?
Return to “Configuration”
