hi to all ...
OXO 700/018.002 version I have a problem that occurs is that when you receive a call the operator and external transfers, the person receiving the transfer is on the screen of your phone number as if it were an extension called an internal sees no indicator of the line of so-called outsourcing.
Plz can give me some advice.
Thank you very much.
Boards
- tot3nkopf
Re: Problem in transfers of external calls
Use rerouting intead of joining as transfer to external option. Your carrier must support this feature.
Regards.
Regards.
- tot3nkopf
Re: Boards
astarot wrote:hi to all ...
moved due to obvious reasons
astarot
Re: Boards
Sorry for not answering, was absent from work due to an accident. Until now go back and see that my post removed.
Rioja proved to comment because the issue continues.
