*.zip file is missing (System is not initialized)
klodjan bregu
Post by klodjan bregu »
I have an OXE IP Media Gateway (Stand alone) system R5.1Lx as below:
There is a crash dump on /dev/crashdump, date: 2000/10/24 21:25:55
# The role of the CPU is MAIN
Application software identity
R5.1Lx-e2.403-7-a-si-c80s1
Business identification: R5.1Lx
Release:
DELIVERY e2.403
Patch identification: 7
Dynamic patch identification: a
Country: si
Cpu: c80s1
ACD VERSION
release : 4
bug_fixing : 4
protocol_id : 80
version_dy_hr_stat : 11
I have creating an empty DB without saving OPS files before. After that I downloaded from Alcatel BP website the *.swk file and uploaded it in the system using ftp connection in /usr4/BACKUP/OPS/
Now I get this error message:
(1)xa001002> test_ops
SYSTEME NON CONFORME POUR LE TRAITEMENT DES ADJONCTIONS
System not consistent to handle properly adjunctions
VEUILLEZ Y REMEDIER EN UTILISANT UNE DISQUETTE OPS
ET LA RUBRIQUE 'Restore OPS files from DOS floppy' DE SWINST
Please correct this by using an ops floppy disk and the
item 'Restore OPS files from DOS floppy' of swinst menus
test_ops: ERROR Can't find any *.zip files in /DHS3data/mao
(1)xa001002> timed out waiting for input: auto-logout
Linux Mandrake for eMediate release 7.2 (Odyssey) for i486
Kernel 2.4.1-ll-dhs3 on an i486 / ttyS0
xa001002 login:
Also there is no connection betwen CS and GD ?!!!
They are in the same range:
GD: 192.168.5.180
CS: 192.168.5.181
Gateway: 192.168.5.1
I have created the shelf, puted the MAC adress of GD and finaly I configured the GD IPs as above. GD bord is registered but not initialized.
I dont understand what caused this problem, the missing OPS files or there is sth demaged.
Please can you help me to resolve this problem.
Kind regards,
Klodjan
sera544
Re: *.zip file is missing (System is not initialized)
Post by sera544 »
klodjan bregu wrote:After that I downloaded from Alcatel BP website the *.swk file and uploaded it in the system using ftp connection in /usr4/BACKUP/OPS/
Hi..
You can't upload the *.swk file directly into the system because already u created the empty DB...so wht u have to do u have to find from presales or sales people actis file which belong to this system...when u click on the file u can see right side status is finished if it's then right click and download the mao which is ur ops file....
Note:- cross verify ur actis file name and swk file names or same...
For GD communication...try this...go to mgr>IP>IP paramater>
Ethernet address checked ny tftp make it false....and it will work...
cheers,
Pandian
ACSE Business R.9.x
alex
Post by alex »
If it is a lab system do not care about these messages.
If it is a production system get all OPS files from your sales person or download them from BPWS and load OPS files as written in the docs.
klodjan bregu
I changed the "Ethernet address checked by tftp" from True to False but the situation is the same.
xa001002> config 1
| 1 | 0 | GD |---------- | REG NOT INIT | NO PCMS CODE |
About the Actis file I can not find it because the presale person in my company has gone and he didnt save it somewhere. I dont know if Alcatel can provide it to me again (we are Alcatel Business Partner)
Is there any way how to make this system operational considering these problems?
Klodjan
sera544
Post by sera544 »
HI..
For GD problem ...do u have same versions in CS & GD and better if u put the GD console trace output here...
ACSE Business R.9.x
alex
Post by alex »
klodjan bregu wrote:...
Klodjan
Download them from BPWS. It is in "eLicensing Management" part, check for "Key inventory for OmniPCX Office, OmniPCX Enterprise, OmniVista, OmniTouch CC" line and click there. You will need to supply CPUID to find your files.
klodjan bregu
In Alcatel BP in the session: e-Licensing Services > My Software Keys you can find only *.swk file but not the zip file.
Please find below the GD and CS trace
GD trace output
*** BIOS Version 3EH30227GLAA bios100/010.011 ***
*** Generated on Jun/15/2007 at 16:16 ***
memory test started lng=133169152 with 0
running flash(soldered=1 socket=0)=1,BIOScase:4,BIOSv24:0,verrou=1,algoNOR=1,siz
e=1,base=3FF80000
DIMM characteristics->: JEDEC Manu ID:ê,......
Memory type(EDO,FPM..):0x 4
# of row address:13
# of col address 9
# of module row 1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI:scan_bus for bus 0
PCI:bus=00h,devfn=00h ,[vendor:device]=[1022h/3000h]
PCI:bus=00h,devfn=60h ,[vendor:device]=[100Bh/0020h]
PCI:bus=00h,devfn=98h ,[vendor:device]=[1064h/2101h]
PCI:scan_buses with 00h secondary buses
PCI:command = 3FFH for device 00:00
PCI: Assigning I/O space FC00-FCFF for 00:60 BAR= 10
PCI:Assign memory space BFFFF000H to BFFFFFFFH for device 00:60
PCI:command = 3FFH for device 00:60
PCI:Assign memory space BFFFD000H to BFFFDFFFH for device 00:98
PCI: Assigning I/O space FD00-FD1F for 00:98 BAR= 14
PCI: Unable to handle I/O allocation for 00:98 (FF04) BAR= 18
PCI:command = 3FFH for device 00:98
assigning irq10 to xchange
B0 = 17
DRCTMCTL = 1E
DRCCTL = 8
DBCTL = 11
Set external RTC
Set Internal RTC
No external RTC detected
gpbus sig timing : 0-2-1-2-1-2!
CMOS is available
Xchange PCI mem base OK: 0,mbx= BFFFD000
dsp_accesses.stat_ctrl= FD00
Xchange PCI IO base OK: 0
Xchange irq OK: A
PCI command read for natsemi : 347
PCI Master Bit Setting...
pci_command set to: 357
0 80 9F 81 AB F2 ,IRQ 12.on interrupt pin:2
eth0: Transceiver status 0x 7849 advertising 5E1
Flashfx version:600.010.500
NAND Flash Comfiguration:
CPU size : 128 MBytes
free spare blocks: 37
NAND Flash Details:
chip #0 : Type=NAND01GW3B Id=20F1H Size=128(MBytes) Unit size=131072
Page Size=2048
time :sec=39,min= 3,hour=14,DoW= 5,date=22,Month= 1,year= 9
time :sec=43,min= 3,hour=14,DoW= 5,date=22,Month= 1,year= 9
ALIZE informations :
Memory Detected : 131072 Ko
Flash Detected
DaughterBoard Detected
DSP Voip Found : 1
XCHANGE Detected
XCHANGE Chip Initialization OK
Ethernet Found : 1
Ethernet Chip Initialization OK
Hard Disk Not Detected
PCM11 selected
CPU at 133 mhz
check lock RTC
value of DIL switch 2
YOU CAN strike Ctrl B to enter in BIOS monitor during several seconds from NOW
BATMODE testing
Static Boot from hard disk #0(3)
unable to boot on DISK
Static Boot from No Boot Device selected(0)
Static Boot from flash NAND mother(1)
BOOT Sector Found on NAND Flash Drive #0
Shutdown of the interface 0 = 0
init ethernet interface 1 not done
Watch dog started
Linux version 2.2.18-rtl (pgorecki@cb150s017) (gcc version 2.95.2 19991024 (rele
ase)) #2 Tue Sep 12 14:34:22 MEST 2006
Calibrating delay loop... 65.74 BogoMIPS
Memory: 122860k/131072k available (632k kernel code, 412k reserved, 1584k data,
36k init)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
ShutOK cleared!
Dentry hash table entries: 16384 (order 5, 128k)
Buffer cache hash table entries: 131072 (order 7, 512k)
Page cache hash table entries: 32768 (order 5, 128k)
CPU: AMD 486 DX/4-WB stepping 04
Checking 386/387 coupling... OK, FPU using exception 16 error reporting.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.2
Based upon Swansea University Computer Society NET3.039
NET4: Unix domain sockets 1.0 for Linux NET4.0.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 131072 bhash 65536)
802.1Q VLAN Support v1.0 (c) 2000 Ben Greear (GPL)
vlan Initialization complete.
Starting kswapd v 1.5
Serial driver version 4.27 with no serial options enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
pty: 256 Unix98 ptys configured
RAM disk driver initialized: 16 RAM disks of 20480K size
RAMDISK: Compressed image found at block 0
EXT2-fs warning: checktime reached, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 36k freed
Warning: unable to open an initial console.
Initial console created for init
RTLinux Extensions Loaded (http://www.fsmlabs.com/)
Starting watchdog timer daemon using /dev/rtf3
modprobe: modprobe: Can't locate module char-major-4
INIT: version 2.78 booting
Remounting root read-write....
e-mgd board found - setting up ramdisk
Remount - Forces the media to be remounted
Datalight FlashFx
V4.06.210 Back ported to OmniPCX MediaGateway
Copyright (c) 1993-2005
Patent US#5860082
Disk Remounted
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
/dev/fla: clean, 127/30360 files, 11389/121396 blocks
/dev/fla on /mnt/flash type ext2 (rw)
Set initial public keys
/mnt/flash/local/ifcfg-eth0: OK
Find ip configuration in /mnt/flash/local/
/mnt/flash/local/startup.cfg: OK
INIT: Entering runlevel: 3 in
Trying to map the io space of the board(=1). Wait 10 sec...
Compression daughter board type [MADA]
mada_3 DSP daughter board
e-MGD version 43.4
Media Gateway Software R8.0 loading ...
No password file found - using default password list
Starting /etc/rcS.d/01fifos
Starting /etc/rcS.d/05syslog
Starting /etc/rcS.d/10network
VLAN REGISTER: Allocated new group, idx: 2
eth0 : chip revision 0403.
Starting /etc/rcS.d/90init
BIOS updater is now working ... getting current version information
Check if we need to update with bios 3EH30227GKAA bios100/010.009 ...
Reboot after bios update is enabled...
----- RetrieveFlashNorInfo -----
NOR VERSION : Bios Version in soldered NOR flash : 3EH30227GLAA bios100/010
.011 len = 28
- Flash Nor Informations -
Flash AMD
Number of sectors : 11
----- CompareBiosVersions -----
CURRENT=010.011 FILE=010.009
* The Bios in Flash is newer than the one found in binaries *
* (use command 'bios_update -force' to force current bios flashing) *
Basic registers of MII PHY #1: 3100 7849 2000 5c21 05e1 0000 0004 2001.
Basic mode status register 0x7849 ... 7849.
Link status: inactive.
Loading modules - please wait ...
Real-Time Linux Dynamic Memory Manager 4.00
RTLinux System Call loaded
Starting USER_PROCCES using fifo 7 6
Waiting for User Process registration
Starting VG_PROCCES using fifo 5 4
Waiting for Vg Process registration
Starting monitor using fifos 1/2
Alcatel kernel module loading...(break=0)
Application User Process registered
Application VG Process registered
Main task created thread_id=0xc52a0e00 stack address=0xc529cd28 stack bottom add
ress = 0xc5298000
DSP Manager OK
watchdogd now in real time mode
Fast Socket Initialization... Ok
============ continue_rack_init ==============
DIL SWITCH VALUE = 0x2
1024 Ko - BUFFER ALLOCATED
MGD - RACK CONSTRUCTION
@ MAC : 00:80:9f:81:ab:f2
@ IP : 192.168.5.180
net mask : 255.255.255.0
gateway : 192.168.5.1
CS role address : 192.168.5.181
CS redundancy role address : 0.0.0.0
Passive Comm server address: 0.0.0.0
crystal number : 1 (Manual allocation)
vlan id : 1
default priority : 0
default dscp : 0
duplex mode : forced 100Mbps/full duplex
download binary timeout : 0
Module MG Loaded:vlan set(1)
watchdogd now in normal mode
RTLinux System Load 1.00
init_module GPA
->insmod GPA
Module GPA loaded
Module APA loaded
Module SLAC loaded
Module DDI loaded
Module UAI loaded
Module SLI loaded
Insert INTX module
Insert ISDN module
Module BRA loaded
Module PRA loaded
Module PRACCS loaded
Module PRA_T1CAS loaded
Module PRA_E1CAS loaded
->init_module eMGA ==> eMGD_eMGA & eMGD_GPA module types created !
Module eMGD_eMGA loaded
Module eMGD_GPA loaded
Module MIX loaded
Module ATL loaded
Module RESCUE loaded
PUC_device registered
Module DPNSS loaded
Module DSPx_LOAD loaded
Module UASIM loaded
====== record_country_correspondaces
====== record_default_country 0 (DEFAULT COUNTRY : HU based with Poland tones)
WARNING: network link not established - check cables
Loading MCV module - please wait ...
Rack 0 is a large
/mnt/flash/local/startemg: OK
Startup completed - awaiting user login ...
DSP firmware successfully read in flash (size=740560)
Starting /etc/rcS.d/99crond
Start VG_PROCESS using /dev/rtf5 and /dev/rtf4
Trace OFF
Welcome to GD
WARNING: root account has no password
Use 'passwd root' to enter a valid password
eMGD login: Inserting country module : country_param_FR.o
country_param_FR.o.tar.gz
country_param_FR.o
rmmod eventuel avant insmod : country_param_FR
rmmod: module country_param_FR is not loaded
puis appel de insmod : country_param_FR.o
====== record_country : 5 (FRANCE)
CS trace output
PCI: Assigning I/O space fd00-fd1f for 00:98 BAR=00000014
PCI: Unable to handle I/O allocation for 00:98 (ff04) BAR=00000018
PCI:command =000003ffH for device 00:98
B0 = 17
DRCTMCTL = 1e
DRCCTL = 18
DBCTL = 11
Set external RTC
Set Internal RTC
Warning : The REG D indicates battery failure
Re-initialization of CMOS
Xchange PCI mem base OK: 00000000
Xchange PCI IO base OK: 00000000
Xchange irq OK: 0a
PCI command read for natsemi : 00000347
pci_command set to:0357
0000 0080 009f 0030 00b5 00c4 , IRQ 12.
eth0: Transceiver status 0x00007869 advertising 000005e1
Hard Disk #0 : TOSHIBA MK2018GAS 19077 Mo
Parameters :
Type 00000
Extended Type 00255
Sectors / track 00063
Landing Zone 00000
Control Byte 00000
Write Precomp 00000
Heads 00016
Nb of Cylinders 16383
HD size(cyl*sec by track*head*sector size) 08455 MO(decimal)
Flashfx version:520.001.001
Cannot mount flash drive No 0. Flash NAND may not be formatted !
CPU size : 32 MBytes
XMEM size : 0 MBytes
NAND Flash Details:
chip #0 : Type=TC58256 Id=9875H Size=32(MBytes) Unit size=16384 Page Size=5
12
time :sec=00,min=00,hour=00,DoW=01,date=00,Month=01,year=00
time :sec=00,min=00,hour=00,DoW=07,date=01,Month=01,year=00
time :sec=04,min=00,hour=00,DoW=07,date=01,Month=01,year=00
RTC Lost Power
Flash Detected
DaughterBoard Not Detected
XCHANGE Detected
Ethernet Found : 1
Hard Disk Detected
Hard Disk Found : 1
DMA enabled
PCM11 selected
Back Panel NMI disabled
No HD trace
CPU at 133 mhz
check lock RTC
value of DIL switch 01
Static Boot from hard disk #0 (3)
valeur index DXCX = ff01feff
GRUB version 0.5.97 (1024K lower / 130048K upper memory)
Press enter to boot the default OS [0], 'c' for a command-line,
or give an another entry number
[0]: Boot GNU/Linux [default]
[1]: Install GRUB into the hard disk
the default entry [0] will be booted automatically in 1 seconds.
Booting 'Boot GNU/Linux [default]'
root (hd0,4)
kernel /boot/vmlinuz root=/dev/hda5 console=ttyS0,9600 panic=5
[Linux-bzImage, setup=0xa00, size=0x83d7e]
Bootinfo src = 0x7ff000 Bootinfo dst = 0xc0107000
Linux version 2.4.1-ll-dhs3 (infrafox@cb100s006) (gcc version 2.95.2 19991024 (r
elease)) #3 Wed Jun 18 16:09:05 MEST 2003
BIOS-provided physical RAM map:
BIOS-e801: 000000000009f000 @ 0000000000000000 (usable)
BIOS-e801: 0000000007f00000 @ 0000000000100000 (usable)
On node 0 totalpages: 32768
zone(0): 4096 pages.
zone(1): 28672 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/hda5 console=ttyS0,9600 panic=5 bipa=0x7ff000
Initializing CPU#0
Memory: 126964k/131072k available (772k kernel code, 3720k reserved, 280k data,
172k init, 0k highmem)
Aspen : mmcr_reg = c8800000.
ShutOK cleared!
Cpu type: CPU80s1
Dentry-cache hash table entries: 16384 (order: 5, 131072 bytes)
Buffer-cache hash table entries: 8192 (order: 3, 32768 bytes)
Page-cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
CPU: Before vendor init, caps: 00000001 00000000 00000000, vendor = 2
CPU: After vendor init, caps: 00000001 00000000 00000000 00000000
CPU: After generic, caps: 00000001 00000000 00000000 00000000
CPU: Common caps: 00000001 00000000 00000000 00000000
Linux NET4.0 for Linux 2.4
Initializing RT netlink socket
Starting kswapd v1.8
block: queued sectors max/low 84322kB/28107kB, 256 slots per queue
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hd1: C/H/S=7/189/192 from BIOS ignored
hda: TOSHIBA MK2018GAS, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: 39070080 sectors (20004 MB), CHS=38760/16/63
Partition check:
hda: hda1 hda2 hda3 < hda5 hda6 hda7 hda8 hda9 hda10 hda11 hda12 hda13 hda14 hd
a15 hda16 hda17 >
Serial driver version 5.02 (2000-08-09) with SHARE_IRQ enabled
IP: routing cache hash table of 1024 buckets, 8Kbytes
TCP: Hash tables configured (established 8192 bind 8192)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
802.1Q VLAN Support v1.3 Ben Greear <greearb@candelatech.com>
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 172k freed
Welcome to Linux Mandrake
Press 'I' to enter interactive startup.
Mounting proc filesystem [ OK ]
Configuring kernel parameters: [ OK ]
Setting clock (utc): Sat Jan 1 01:00:21 CET 2000 Sat Jan 1 01:00:21 CET 2000
[ OK ]
Activating swap partitions: [ OK ]
Setting hostname xa001002: [ OK ]
Checking root filesystem
DHS3ROOT: clean, 15369/128016 files, 96609/512032 blocks
[ OK ]
Remounting root filesystem in read-write mode: [ OK ]
Finding module dependencies /etc/rc.sysinit(1): Finding module dependencies
[ OK ]
Checking filesystems
DHS3ROOT2: clean, 11/128016 files, 16169/512032 blocks
/etc/rc.sysinit(1): Checking filesystems
[ OK ]
DHS3BIN: clean, 1351/128256 files, 65677/256024 blocks
[ OK ]
DHS3DATA: clean, 3594/128256 files, 27483/256024 blocks
[ OK ]
DHS3DYN: clean, 1530/544000 files, 38925/1086238 blocks
[ OK ]
DHS3BIN2: clean, 11/128256 files, 4039/256024 blocks
[ OK ]
DHS3DATA2: clean, 11/128256 files, 4039/256024 blocks
[ OK ]
DHS3EXT: clean, 60/256512 files, 18888/512056 blocks
[ OK ]
DHS3VAR: clean, 127/102800 files, 49159/409601 blocks
[ OK ]
DHS3VAR2: clean, 11/102800 files, 12991/409601 blocks
[ OK ]
Mounting local filesystems /etc/rc.sysinit(1): Mounting local filesystems
[ OK ]
Checking loopback filesystems
/etc/rc.sysinit(1): Checking loopback filesystems
[ OK ]
Mounting loopback filesystems: /etc/rc.sysinit(1): Mounting loopback filesystem
s:
[ OK ]
Enabling swap space: /etc/rc.sysinit(1): Enabling swap space:
[ OK ]
Entering non-interactive startup
Starting dhs3mod: Loading Alcatel-specific modules: /etc/rc3.d/S02dhs3mod(1): d
hs3mod startup
[ OK ]
/etc/rc.d/rc(1): Starting dhs3mod:
[ OK ]
Starting eva: Loading Alcatel-EVA modules: /etc/rc3.d/S02eva(1): eva startup
[ OK ]
/etc/rc.d/rc(1): Starting eva:
[ OK ]
Starting kdebug services: new debug mode: dump
/etc/rc3.d/S02kdebug(1): Starting kdebug services:
[ OK ]
Starting watchdog: Starting watchdog services:
/etc/rc.d/rc(1): Starting watchdog:
[ OK ]
Remove not allowed accounts: /etc/rc3.d/S09security(1): Remove not allowed accou
nts:
[ OK ]
Setting network parameters: /etc/rc3.d/S10network(1): Setting network parameter
s:
[ OK ]
Bringing up interface lo: /etc/rc3.d/S10network(1): Bringing up interface lo:
[ OK ]
Enabling IPv4 packet forwarding /etc/rc3.d/S10network(1): Enabling IPv4 packet f
orwarding
[ OK ]
Bringing up interface eth0: /etc/rc3.d/S10network(1): Bringing up interface eth
0:
[ OK ]
Starting netadmin: /etc/rc.d/rc(1): Starting netadmin:
[ OK ]
Starting netadmind: /etc/rc.d/rc(1): Starting netadmind:
[ OK ]
Initializing random number generator: /etc/rc3.d/S20random(1): Initializing ran
[ OK ]
Starting gwlinuxfifo: Creation de la fifo:
/etc/rc.d/rc(1): Starting gwlinuxfifo:
[ OK ]
Starting pwr_mgt: /etc/rc.d/rc(1): Starting pwr_mgt:
[ OK ]
Starting system logger: /etc/rc3.d/S30syslog(1): syslogd startup
[ OK ]
Starting kernel logger: /etc/rc3.d/S30syslog(1): klogd startup
[ OK ]
Starting dhslog: Loading Alcatel-specific log functionality: /etc/rc3.d/S31dhsl
og(1): dhslog startup
[ OK ]
/etc/rc.d/rc(1): Starting dhslog:
[ OK ]
Starting at daemon: /etc/rc3.d/S40atd(1): atd startup
[ OK ]
Starting cron daemon: /etc/rc3.d/S40crond(1): crond startup
[ OK ]
Starting xinetd: /etc/rc3.d/S65xinetd(1): xinetd startup
[ OK ]
Starting kheader: /etc/rc.d/rc(1): Starting kheader:
[ OK ]
Loading chorus/mix emulation layer:/etc/rc3.d/S98emulation(1): S98emulation
[ OK ]
Starting alzled: /etc/rc.d/rc(1): Starting alzled:
[ OK ]
automatic start of dhs3 is about to begin
waiting 5 seconds before starting ...
type CR key to stop
Too late. Automatic start of dhs3 is in progress
Starting the TEL applications: /etc/rc3.d/S99tel(1): S99tel
[ OK ]
Starting thttpd: /etc/rc3.d/S99thttpd(1): thttpd startup
[ OK ]
xa001002 login:
Building Menus, Please Wait \
Bye Bye
ERROR (-7): can't send message
SERVER ALREADY ACTIVATED : OK>> RemaDaemon starts ... (using static user group n
o 3)
Remanent loading ...
/..........01/01/00 01:02:10 000001I|--/--/-/---|=4:2199=A4400 Version : R5.1Lx-
e2.403-7-a-si-c80s1
......01/01/00 01:02:13 000001I|--/--/-/---|=2:4351=Incoherent data: appli INITR
EM table ENTITY cause 0 info -1 -1 -1
01/01/00 01:02:13 000001I|--/--/-/---|=2:4351=Incoherent data: appli INITREM tab
le ENTITY cause 1 info -1 -1 -1
9 region(s) flushed
Actor MONITELmod started, pid=782
Black box recording started...
mtracer started ...
(001541:000000) btracer message to get monitel time base
dectobsproc background process...
Waiting for messages...
01/01/00 01:02:52 000001I|--/--/-/---|=2:2176=A dynamic patch has been installed
for TEL
(001612:000001) TSS_BIND zone SIP 0x120b2be4 lg 140
(001612:000002) acces monitel 0xc8ea2be4
(001612:000003) zone mappee:
(001612:000004) Dump: .ff.ff.00.00.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.
ff
(001612:000005) Dump: .ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.00.00.ff.ff.ff.ff.ff.ff.ff.
ff
(001612:000006) Dump: .ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.00.
00
(001612:000007) Dump: .ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.
ff
(001612:000008) Dump: .ff.ff.ff.ff.ff.ff.00.00.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.
ff
(001612:000009) Dump: .ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.00.00.ff.ff.ff.
ff
(001612:000010) Dump: .ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.ff.
ff
0
(001764:000011) IPLINK initialize -> 70000000
Actor MON25mod started, pid=889
(001766:000012) monix_actor add 0xc8f24290:3371319952 Value 659456
(001767:000013) ** x25 started **
lancement de dis25
(001850:000014)
(001850:000015)
--------------- Network Builder E1 1.0 12-15-01 ----------------
(001850:000016) Start Remanents Packet Handler : 16360000
(001850:000017) Packet Handler Total Remanents : 000792 Ko
(001850:000018) Packet Handler Dynamiques Remanents : 000511 Ko
(001850:000019) Current Pointeur : 00001104 o
(001850:000020) Stop Pointeur : 00524287 o
(001850:000021) Free Packet Handler Remanents : 00523183 o
(001850:000022) FreeMemory : 056484 Ko
(001850:000023) LockMemory : 000000 Mo
(001850:000024) TotalMemory : 000124 Mo
timed run as effective root user-id.
(002102:000025) dl_id 8 appli_cap.ui 794624
(002102:000026) dl_id 34 appli_cap.ui 794624
(002102:000027) dl_id 83 appli_cap.ui 794624
(002102:000028) dl_id 84 appli_cap.ui 794624
(002102:000029) dl_id 94 appli_cap.ui 794624
--> ACCOUNTING 0 tickets stored in database
v24_config daemon 4.3 started (/dev/console)
01h04:33 Demarrage CCS Server ...
01/01/00 01:04:48 000001M|--/--/-/---|=4:4017=CSTA server : new creation 4 192.1
68.5.181
Cyclical test of couplers :
| CRYSTAL | STATE | PERIOD |
| 0 | ON | 3 |
| 1 | ON | 10 |
| 2 | ON | 10 |
| 3 | ON | 10 |
| 4 | ON | 10 |
| 5 | ON | 10 |
| 6 | ON | 10 |
| 7 | ON | 10 |
| 8 | ON | 10 |
| 9 | ON | 10 |
| 10 | ON | 10 |
| 11 | ON | 10 |
| 12 | ON | 10 |
| 13 | ON | 10 |
| 14 | ON | 10 |
| 15 | ON | 10 |
| 16 | ON | 10 |
| 17 | ON | 10 |
| 18 | ON | 10 |
| 19 | ON | 10 |
RespTimeOut : 5 sec.
InitialWait : 30 sec.
NbFaultAccepted : 1
Cyclical test of auxilaries :
Test active
Periode : 180 sec.
RespTimeOut : 10 sec.
Maintenance of DECT base stations is already active
open file /DHS3bin/mtcl/mtcl.cron
read usr crontab
open file /DHS3bin/oneshot/mtcl/business.cron
read usr crontab
open file /DHS3bin/oneshot/mtcl/hotel.cron
#OBST 01:06:04 01/01/2000 : /DHS3bin/servers/obstraf is running in version 3160
0
Command "TEST_OPS" (pid 1171) exited with status 1.
No problem with compatibilities
@@@@@ Begin of 4760i_OnStartUp at Sat Jan 1 01:06:23 CET 2000
/DHS3data/httpd/nmc/html/templates/callindex.html -> /DHS3data/httpd/nmc/html/ca
llindex.html
Tag '@IPADDRESS' replaced 1 time(s) in file '/DHS3data/httpd/nmc/html/callindex.
html'
/DHS3data/httpd/nmc/html/templates/nmcsec.bat -> /DHS3data/httpd/nmc/html/nmcsec
.bat
Tag '@IPADDRESS' replaced 1 time(s) in file '/DHS3data/httpd/nmc/html/nmcsec.bat
/DHS3data/httpd/nmc/html/templates/saveres.html -> /DHS3data/httpd/nmc/html/save
res.html
Tag '@IPADDRESS' replaced 1 time(s) in file '/DHS3data/httpd/nmc/html/saveres.ht
ml'
@@@@@ End of 4760i_OnStartUp at Sat Jan 1 01:06:25 CET 2000
@@@@@ Begin of 4760i_runconf at Sat Jan 1 01:06:34 CET 2000
call run()
In run(), monitor wait()
sera544
Post by sera544 »
klodjan bregu wrote:----- CompareBiosVersions -----
Hi..
Your GD and CS bios version is mismatch..i faced the same problem...you have to reinstall the GD binaries which ur using in CS...Make sure GD installtion is proper ..when u do the GD binary installtion it has to restart 3times until u should not close the PC installer, so all the tables will be updated from binary installation...if u want u can cross check TC0521...
cheers...
ACSE Business R.9.x
alex
Post by alex »
klodjan bregu wrote: In Alcatel BP in the session: e-Licensing Services > My Software Keys you can find only *.swk file but not the zip file.
So your sales person did not leave anything from ACTIS? Strange.
Just create similar offer in ACTIS and get files from there.
vlan id : 1
You use VLAN?
Is ethernet OK?
Gedeon
Post by Gedeon »
Check your network configuration, if VlanId is managed on GD but not on CD, downloading is impossible.
And if your network architecture don't authorize vlan, it's the same problem.
Check if you have managed the role addressing, in this case, the GD must have the CS role address.
And, for reduced source of problems, connect the GD to the CS with a crossed cable, or via a LANX (the S-LanX is not a very good solution...).
For the zip file, there is not a problem for running the system.
It's only used by Actis man's to upgrade a configuration. It's a file that contained the configuration, offer, ops and many other files generated by actis.
If you wan't to see this message, just get the offerId by the command ls /usr3/mao/*.swk
If the response is (ie) df00345c.swk, just create an empty file with the command
touch /usr3/mao/df00345c.zip and run the command test_ops to check if the result of the test is correct.
In this case, you haven't message, but you can't upgrade your configuration with actis, it's mandatory to reconfigure the second offer from scratch.
G.
Return to “Swinst”
