Page through sets
pryan
Page through sets
Post by pryan »
Is there any way to page through the sets in a Enterprise system. I just need a few users to be a part of the group to receive the broadcast. I read in a document somewhere on How to Broadcast a message to the speakers of a station group. It indicated that all you had to do was dial the number of the station group, then you had up to 20 seconds to speak, then hang up. It said it would come out the speakers of all sets in the group unless they were in use. How can I do this??? This is exactly what I want.
Paul
goldy
Post by goldy »
Hi Paul,
There is a feature called intercom list from memory, which sounds like it would do the job. I ccan't remember exactly the configuration for it, someone else might. If not, I will try to find it for when i get time :)
iourid
Post by iourid »
Check alcatel documentation: /user services/Mastered conference. It works exactly as you want but I believe you will need some licenses.
Iouri
pryan
Post by pryan »
Iouri.
I was literally given zero documentation on the system. Where can I find this doc?
Paul
iourid
Post by iourid »
viewtopic.php?t=294
Thanks to Frank!
also in the business partner web site (you need a login)
http://www.businesspartner.alcatel.com
Return to “GENERAL”
