BLF with MAC59
asgharp
BLF with MAC59
Post by asgharp »
hi all,
i install MAC59 on windows xp and also BLF. and in OXE Rel 8 i creat operator set as MAC59. and i gave the shelf board and port location and connected to system MAc59 working fine but blf is not working it's giving message no source network cable also connected and in blf setting access i selected com1 and mac59 is it ok or there is some other setting waiting for you help
Regards.
Re: BLF with MAC59
Not remember exactly but some times ago was the same problem.
4059 have "internal mini-BLF" feature. And you can use external (full) BLF. But not in the same time.
Us I remember I forbin internal BLF.
But not sure. It was many time ago :(
asgharp
Re: BLF with MAC59
Post by asgharp »
i also disable min blf from services is it same way or from some other place i have to disable it
Re: BLF with MAC59
Not remember - may be during 4059 installation you have possibility to select need or not internal BLF feature?
Re: BLF with MAC59
I think in 4059 configuration parameters must exist option for "mini-BLF" feature disable.
knightr1der
Re: BLF with MAC59
Post by knightr1der »
mini-BLF is free. Big BLF (install separately to 4059 - but on the same CD) is licensed on OXE
asgharp
Re: BLF with MAC59
Post by asgharp »
yes both are installed seprately and there is license for blf
knightr1der
Re: BLF with MAC59
what version you installed?
Can you paste your Attendant config on here?
Eliott_DUP
Re: BLF with MAC59
Post by Eliott_DUP »
Check the OPS using cfgUpdate and look for parameter 43 Number of BLF.
The integrated half BLF can (and must) be disabled in the A4059 configuration menu.
The integrated half BLF also doesn't support supervision of stations in a network!
asgharp
Re: BLF with MAC59
Post by asgharp »
thanks for all of you it's working fine
Return to “Attendant”
